normally, we turn the key to 'on' position, then turn some more to 'start' position to start the engine then release. that's normal way.singchaii said:Can i know what the engine start button use for? Start car without using key?
Your car interior look so clean.. How you clean it? Can't see dust also..
thanks thanks... but some advice me to use relay.... i dont know how thw wiring should be if use relay... haha...Sky_Legend said:wow Skywalker, thanks for the info sharing on ur ignition DIY switch, man. i have been curious of which wire to solder for sometimes. now i really have a clear picture of how to DIY it. thanks man.
however, one question: how do u remove the wire-bunch from the key-kneck? where are the screws?
in short, jz for fun... hahaha....Sky_Legend said:normally, we turn the key to 'on' position, then turn some more to 'start' position to start the engine then release. that's normal way.
but now, we want to have engine start button similar to many high-end cars. haha... like the S2000, etc.
so, what we are trying to do is, just having the key turn to 'on' position, then press the 'engine start button' to start the engine, then release the button.
Cool way of starting engine. haha...
yah.... i do experience it sometimes.... jz click click sound... not sure yet why is this la... but after awhile, i can use the button and start engine again....Sky_Legend said:hey skywalker...do u have any problem with the start button? something like sometimes press can start and sometimes press but just heard click click sound but cannot start/crank engine. i think i'm having that problem. so, have to go turn the key to start engine.
any knowledge sharing?
yeah...i am having that problem...today i just re-wired it with another type of wire...was using multi-core wire. now using single core (thick). still the same things.SkYwAlKeR said:yah.... i do experience it sometimes.... jz click click sound... not sure yet why is this la... but after awhile, i can use the button and start engine again....
u also experience this??... why ar??...
mayb later i gonna add relay to the starter button la... i got the wiring diagram adi...:regular_smile:
well, either the switch or wire lo...will change to thicker wire first...then if still the same, will find bigger switch...if still cannot, then add relay...if all cannot, remove...:baring_teeth:SkYwAlKeR said:waa..... vr complicated explaination.... so conclusion, u mean the wire couldnt carry enough current to jump start the car??... possible.... i'm currently using multicore (thin) wire.... i dont think its enough... coz i'm using the same wire for my foglights and they get heated up vr easily.....
so, conclusion, go and get bigger wire....
HEy...i'm back!! SO any one have an idea of how i wan2 have same ignition button with my iswara....is the white cylinder things are the same for all car?and after you have install the button you still can start normally using the key? i scare after i have install it my dad thought the car is dead coz the car cant start HAhaSkYwAlKeR said:latest DIY update: cheap skate engine start button...
first, go electronics shop buy a nice suitable switch.... mine cost 3bucks...
after that, solder 2 wire to the switch like this....
http://i61.photobucket.com/albums/h73/kahchai/DIY%20engine%20start%20button/DSC06816.jpg
after that, remove the panel that covers the key ignition...
http://i61.photobucket.com/albums/h73/kahchai/DIY%20engine%20start%20button/DSC06817.jpg
check and see which wire to tap..... (vr hard angle, need to lie down on the floor)
http://i61.photobucket.com/albums/h73/kahchai/DIY%20engine%20start%20button/DSC06819.jpg
lucky i saw a screw in between the wires.... unscrew it and take the whole thing out.... now easy to see lo...
after u know which wire to tap, solder the wire from ur switch to the key ignition...
http://i61.photobucket.com/albums/h73/kahchai/DIY%20engine%20start%20button/DSC06820.jpg
another shot...
http://i61.photobucket.com/albums/h73/kahchai/DIY%20engine%20start%20button/DSC06821.jpg
another one... hehe...
http://i61.photobucket.com/albums/h73/kahchai/DIY%20engine%20start%20button/DSC06822.jpg
DONE~!!!!
http://i61.photobucket.com/albums/h73/kahchai/DIY%20engine%20start%20button/DSC06823.jpg
:regular_smile: :_:
I guess all iswara will have the same white cylinder thing, because my iswara sedan also having the same one. and of course u can follow the wiring that is shown in the picture posted by skywalker to build ur own engine start button. nevertheless, u can still start ur engine the original way using key. either way la.David_1211 said:HEy...i'm back!! SO any one have an idea of how i wan2 have same ignition button with my iswara....is the white cylinder things are the same for all car?and after you have install the button you still can start normally using the key? i scare after i have install it my dad thought the car is dead coz the car cant start HAha
