:mouth_closed: I got a friend who's GSR kicks out 240hp on wheels boosting 1 bar with a TD05 and stock internals. He did try a 1.5 bar run it gave out 280hp.
We believe and almost can make sure that when we looking at this Mivec turbo dyno chart, if let it boosted up to 2.0kg/cm2. , it definitely can have big improvement in hp output. But you will never do this when you consider the reliability and wear & tear of a dairy driven engine, if you don't do this, it does mean you don't have an sucessful mods here.
This should be the main reason why some tuners wanted to D-Tuned their engines!
:mouth_closed: I know of a waja bolt on turbo (on the stock waja 1.6 engine) which kicks out 180hp with 0.8 bar boost with a TD04L... all thanks to the standalone. With his previous setup on a piggy back ECU, he was only getting around 130hp at the same boost readings.
If this really happaned. It means this tuner does not have enough ECU know-how to bring the stock ECU to a much higher level of modification. this is why some tuner always find it is easier to disturb most standalone ECU but not stock.
Another thing we always in doubt is: How good is his standalone tuning after couple of time taken when compare to stock unit.
