Joeker said:I doubt t/c will melt ISC.
ANyway, don't waste time anymore with Mitsu/Proton ISCs, mod Toyota FICD and problem solved.
dolly said:the ficd i installed is like a switch/relay that allows air to go through once it is turned on. It is usually hooked up to the aircond compressor, so when it kicks in, the FICD will turn on allowing more air to the motor. This will help increase the idle rpm. Usually you'd need this if you install a standalone ems with no support for idle control (e.g. microtech)
