ok, i eat my words again. whahahaha.... DLS...... ULTIMATE.... what can i say... look at the spec alone sudah cukup
WTS: DLS A6 Mono block - 1200 watt in 1 ohm!
Asking $800, new one cost $1300 easily. Sms or call to view and listen.
Some info:
ULTIMATE series A6. A 1 ohm stable monoblock that´s perfect for the SPL competitor. Extremely powerful power supply. The output power in 4 ohms are 500 thrue RMS watts. A cooling fan is built in but the amplifier also provides a built-in fan control for external cooling fan.
Built-in, variable 50-125 Hz low-pass filter for subwoofers plus a 25 Hz subsonic filter with an 18 dB/octave slope. Dual power terminals where you can connect dual power feeds or a DLS Power Cap. Extra features are a phase control variable 0-180 degrees continiously.
A remote sub level control is included. Adjust the sub level and phase from the front seat!
RMS output per channel at 13.8 volts, < 0.1% distortion.
Mode : AB
Number of channels : 1 ( for subwoofer use )
Nominal power in 4 ohm : 500 W
Nominal power in 2 ohm : 870 W
Nominal power in 1 ohm : 1200 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0.2 - 7 V
Filters : Lowpass: 50-125 Hz. Subsonic: 25 Hz
Terminal for external cooling fan : Yes
Dual DC-inputs : Yes
Phase control 0-180 degrees : Yes
Remote sub level control with phase shift : Yes
Current draw, idle : 0.6 A
Current draw, maximum : 140 A
Dimensions W x D x H : 410 x 240 x 73 mm (16.15 x 9.45 x 2.87 inch)
Weight : 6.2 kg (13.67 lb)
Age: 1 yr +
Excellent to drive subwoofer!
Almost like new condition.
Serious buyer, please sms your offer to 90 21 90 42.
Thanks.
