swgiant
Interior lighting is dim even without turn on the headlight
2 months ago, this issue only happened when i turn on the headlight at night. The lighting of clock, air-cond panel, front meter dashboard is very dim, can say only 50% of lighting output.
Sometimes even worse, very hard to see the clock wording at night and only 25% of lighting output. However after few minutes of driving, the lighting output is getting better again and at least can back to 50%.
I felt shock to see that, only the radio panel lighting is normal and the air-cond still can blast to the max!
I dont think the Interior lights dim when the headlamps are turned on to reduce glare at night, because since last week, the problem is getting worse! Now, the lighting dim all the time even without turn on the headlight, only 50% of the lighting output! When driving at night and turn on the head light, the interior lighting is only left 25% constantly. The radio lighting and aircond still can blast to the max, very weird!
So, what is the problem likely to be?
I am driving 23 years old car, so no dimmer switch built-in at that time.
