.: Exhaust Modification Corner :.
what is adjustable & attachable silencer ?issit suitable for me to install?
lose power after change s flow muffler
I need a help for anyone here know about LANCER GLX 05 exhaust system.because my car lose around 20% power after i change my original to a S flow muffler.Now im feel that the air in the exhaust like less pressure.so easy to step high RPM but fel the power refuse to come.it is obviously.what can i do now?change the extractor 4-2-1 will help?Or i ned to make the muffler hole smaller so can be push for more pressure like before?
what else can i solve this problem without change the middle part?
.hope u guy who expert for this can help me.thank...........
hmmm... wanna ask those exhaust sifu here... i bought a taiwan product muffler la... the tip there got those blue colour thingy ar !!! izzit can be remove or it wont come out when washing it?!
okhmy said:
For satria se 1.5 manual pipping what inch best ar..
Currently using mivec 5zigen exhaust system 2.2 inch, noisy like hell want pengsan edi somemore its jasma certified mufler , plan to use back the mufler but change the pipping. So need some advice on the size of the pipping and need put .
Thanks in advance
2.2" piping is way too big for a 1.5 manual. Your pick up will drop significantly. You can use back the muffler but don't keep such big inlet piping. 1.8" is best for high way + city driving. If KL city, 1.7" good enough.
Bro, just in case you didnt see my PM, auto tranny for a car like yours probably suffering from lack of backpressure. From the content of your post, it is clear that the culprit is the sflow muffler. I suspect the sport sflow you changed has less blocks that allow exhaust flows fast enough. Anyhow, 4-2-1 extractor might help you to get back some low end torque , BUT , IF you're very concerned bout the result after changing, get those which are dyno tested especially dyno for the same car model like yours. Just my 2 cents.
need some help here
my 280ZX nissan is currently using stock muffler and piping. im thinking of 2.0" muffler & piping. straight flow looks nice esp with the titanium tip
so will it drop the car power ? the stock one is very small. same size like the wira.
sumore the car got siput wan..
need help..
faqroul: i sent u a pm..wanted to know more bout ur current setup and ur car's spec.
morning brotherlove
need you advise,
currently i use 2inch piping with standard (ori) exzoz , bcoz muffler (cap ayam)lama dah pecah,(temp. guna),
Plan nak beli muffler baru.....
saya mahukan sound yang very2 slow, tapi berkuasa
dan ko$$$$$$$$....berapa?
my machine is AE101 20 silver factory standard
Thakyou, dan senyum selalu
what exhaust or back box would give the best sound for a boxer engine?
N1 style muffler will give u a nice subtle during idle and during cruising , you will get some 'boiling water' sound... choose the right one..
kweng, do u have Mugen S-Flow or Spoon S-Flow mufler?
how much it cost? if have photo is good too.
cheers...
bro,
if my car changing twin loop exhaust box... can i using back my mid box "bullet" is it sutteable?
dude sitnalm... my opinion nia...
there is only 1 thing left to do.. chg to aftermarket performance s-flow muffler.
piping i dont think necessary to change diameter.. unless u put turbo/superchager.
kweng... answer meee laaa... wer r u bro?
"kweng, do u have Mugen S-Flow or Spoon S-Flow mufler?
cheers..."
donCityz: on dialup currently.. here it is : http://www.zerotohundred.com/newforums/../engine-and-performance/122627-wts-new-twin-loop-muffler-mugen-replica.html
how bout me kweng84!!!! need change mid box ? for twin loop exhaust pipe...
bro need you guyz opinion on diz... i will be modding my waja 4g18p(A) exhaust system and my setup will be like diz changing the standard stock piping to a white metal or in canto "pak kong" and the piping will be longer than the stock.. i will take out the CAT and doesnt plan to replace it with performance bullet as stock ady have it.. and will slot in a kakimotor sflow muffler... so all the sifus here do give some opinion on diz setup... ohya i wont be changing the extractor but will change the air filter to k&n drop in air filter...
Hmm need some advice
Driving satria 1.3(m)
If i choose straight muffler, is bigger or smaller better ?? i heard some also mention smaller cc car dun use too big @_@
but some advice me use bigger wan better ... more power n bla bla
