Apache91120
- Joined
- Aug 25, 2014
- Messages
- 97
- Reactions
- 2
Experiencing this problem lately. Sent to Proton SC to check but they say "everything is OK" but the problem still exist. What could it be?
It will happen once or twice a day. If it is brake problem then it might occurs every time I stop but it should be checked too. It feels like the engine is going to die off but so far it didn't perhaps because I will change the gear to Neutral.
Since you mention putting in neutral is okay, probably your idle speed is too low, so when in gear the engine is vibrating in low idle....
Idle speed is correct, same as before the problem started.
Or it could be a clogged TB?
I have been recommended to a workshop in Taman Petaling Utama, P.J. Called the owner yesterday and he said to bring the car for checking.
---------- Post added at 09:59 AM ---------- 6 hour anti-bump limit - Previous post was at 09:57 AM ----------
What is this & where is this thing located?
Give it up. Its normal. It feels like choking then it jerks.
But actually, yeah, it is normal. Mine 2012 Persona Auto as well.
Air cond compressor kicked in is worse.
No, it is surely not normal. When something is not right, it should be checked & rectified. Normal principle in everything.
But do you know all Personas are like this?
didnt know that.
will see if its the same on my friend pesona this afternoon.
