MIVEC RS has all like what you have mentioned. Plus the front brakes must be 2 pot calipers. Internally, it should have titanium valves, slightly bigger extractors and slightly higher cams with different ECU where the MIVEC kicks in at 6200/6500 and standard rev cut is at 9000. Remember to change your fuel pump or use the MIVEC original fuel tank because our standard fuel tank is not enough at 8000++RPM....
thanks wajafly, dat was internally, the simple thing is bring someone expert or whose know well when buying engine / halfcut
so norns, wat engine lantai u planned for?? is it mivec??
