Ok here is an idea. Electronic turbo...mild boost. Get a turbine and modify it to fit a 12v high speed brushless motor (seen some at 70000rpm at 50kW)....Drive the compressing blades into trottle body. Turn on only when you want. When turned off, some kinda sollenoid to change air flow around turbine. Meaning to say that from air filter 2 pipes split. 1 to turbine...and another joins back after turbine...so you routed the air manually.....interesting idea....not sure will work.
