e-manage VS VAFC-2... wat's ur comment?
Let me preface this by saying that JUN3 are great camshafts and rightly so because most people have not found camshafts that make better power. This does not mean it can not be done. (Important lesson here: DO NOT LET THE LIMITATIONS OF OTHERS LIMIT YOU).
Before I go into specs and details, RM is and will always be grateful that the owner of this motor Arno (98itr484) for putting together a bad ass motor and gracious enough to share his dyno tuning sessions. THANKS ARNO AND FRIENDS!!!
I expect to see a 25 - 28whp gain from the m22 cams / Rocket Head
So far Arno is 10hp over his previous setup even with the stock injectors maxed out and the run cutoff at 8.0K due to fuel starvation.
Old Setup 205.6 whp / 131.8 tq
Intake: J's Racing
Throttle Body: ITR
Intake Manifold: ITR
Injectors: Stock
Camshafts: JUN3
Springs/Retainer: JUN Dual Springs / JUN Ti Retainers
Valves: ITR
Cylinder Head: ITR
Cam Gears: JG Adjustable
Bottom End: USDM ITR 81.00mm Bore
Compression Ratio: 10.6
Header: SMSP 1.8L 4-2-1 Odd Paired Long Tube Header
Exhaust: Spoon
Fuel Management: Chipped P28 w/ VAFC
New Set-up 223whp / 145 tq on most recent re-dyno. 230+ with Shawn Church Magic Intake.
Graph shown is 215.8whp initial dyno.
Intake: Same
Throttle Body: Same
Intake Manifold: AEBS
Injectors: Same
Camshafts: M22 254 duration @ 0.050. 12mm Lift In/ Ex
Springs/Retainer: RM G1 Springs / G2 Ret 95lbs on the seat, 265 at 12mm
Valves: Supertech 33.0/28.0 Int/Ex flat faced valves
Cylinder Head: RM J4 B16 Head. High Flow / Low Turbulence Ports. Milled 0.025
Cam Gears: Same
Bottom End: Same
Compression Ratio: 11.2
Header: Same
Exhaust: Buddy Club
Fuel Management: Hondata S200
just a v-afc will do.. i myself using v-afc onli....just tune abit.. V-tec open late abit.... you will get more mileage... really.. trust me.. this is wat i do when i drive my EK to genting....
and lastly.... you yourself how to drive when on the road... like my friend he drive slowly...
when a first gear not even hit 2000RPM he change get and acc hard... .. you get wat i mean..?
soulfly said:
B16A1 ecu is PW0 and PR3....
P28 is B16A2... no?
upss... yea b16a2
like cipan said... too much net reading can coz hazard :)
