DIY Engine Oil Change
loosen de nut n let it drip all out?? how long will it take for de oil to drip out???
u think everybody so free meh??
http://www.fumotovalve.com/
this product is not worth it la. so expensive just for that. convenient la but that price is too much la
guan,
mind asking .....where you throw the oil ? :rolleyes:
guan,
Mind asking ...where you throw the oil ?
One suggestion, can you included engine flush in the process.
Peace .... :biggrin:
i din throw de oil... it is illegal n will harm de environment... i send to my mech... they will keep it as there will be ppl coming to collect from the mech for a price...
engine flush process?? nothing special la..
to do a proper engine flush... u need to flush 2-3 times at least with clean engine oil... for me... 1st pour a bottle of flush fluid into ur already dirty engine oil... let ur engine run for 20mins... then drain it... pour in new engine oil... n pour in again new flush fluid.. n run ur engine for bout 10-15mins... repeat this process until de oil drained is clean enough... u will need about 12liters of oil for this(according to some SC).... use cheap engine oil for flushing will do...
lastly pour in ur engine oil n top up to de level necessary... hope dat helps..
hey guan...thx for ure info..and i wanna know also that how to take out the spark plug?i wan change that also leh....and....where to get the wrench to open the old oil filter..?
sorry bro..i am driving a CLK....same step as u show here rite?
bro..i saw diy daul air twister on ure website there....how to do that??i saw the Mr JohnsonLam thread got teach this b4...but i can find it...
ok.. one by one...
oil change n flush... ok... if ur CLK is produced by Perodua... then its same steps n procedures... but if ur CLK is produced by Mercedes... then i would recommend u to send back to the authorised SC.... i heard it is diff to service a Merc...
for spark plug, get de spark plug wrench from hardware shop or sparepart shop... make sure u tell them ur car model as diff car model got diff size...
oil filter wrench - can get from hardware shop or acc. shop... shoping mall also got... got a few types... i use de cheapest.. hehe...
air twister - made of 3" PC fan blade... center part cut a hole to eliminate unnecessary air restriction... stuff into de rampipe... u may use double sided tape (foam type) to secure it if it is loose...
New Posts
