Yes..can use SVT wiring with BT ecu,no need to change to BT wiring,just have to mod the SVT wiring to fit.
nothing much different...
look still like SVT, only without AFM...
main fuse box...optional...you still can use the old one, or blacktop fuse box...
you must use a gadjet to override it...like RSM, Pivot baby speed meter and others...
only super sifoo can override the exist chip inside the original ECU...eqeqeqqe
aiiikkk... that gadjet can overide the RPM limit? Not only overide the speed limit?
I think just need to jump some wire in the BT ECU and Tanam Map sensor and 02 sensor like my friend say.
i saw some Gui Lao web site, they say have some idle issue after the conversion.
mmm,got da pic???i really need to see the engine's pic after mixing the SVT with BT wiring n how they adjuz their air filter...
hahha...yaaa lor...my bad...:slug:
almost a year of post...only now someone realize it...
heee...sorry...it's not the RPM but the gadjet will eliminate the speed limit...
thanx scomatic for reminding me...
the main reason why they wanted to convert a SVT engine from AFM to MAF... is because of this :
GZE is a forced induction system...not much diff i think...
