to clock ur timing using rsm is not accurate but still can help.
zaki said:peak hp doesn't occur at peak torque. peak hp occurs just before the hp curve drop. peak torque is where engine acceleration is the greatest. that's where engine efficiency is the highest.
torque is proportionate to air flow. as long as hp increases with regard to RPM, there will be air flow in & out. after peak torque, air will flow lesser as RPM increases. the torque curve indicates air flow pattern. as RPM goes up towards redline, engine efficiency will drop tremendously. this is the region where HP will stop rising. the engine will be having difficulty to breath.
