I list down the little bits that i know about clutch problem through my lesson learn the hard way (thinner wallet kinda way)..Yong_5290 said:wah...so scary meh...my clutch also dying edi wor..but mine cable...
tekan anytime also got sound...hahaaha
and memang its hard
yes tajul... im was feeling this... but got it done last saturday aredy...tajulsans said:2. Worn clutch plate & cover
- Whinning sound when idle, but less significant when depress clutch pedal
- Clutch slip especially during hi rev, more obvious in 2nd or 3rd gear
- Clutch pedal feels significantly harder, (could be false alarm for cable type as the cable tend to be sticky over time)
partyJOE said:yes tajul... im was feeling this... but got it done last saturday aredy...
then now facing another freaking problem wit my ride.... sumthg has stuck at the bottom of timing belt pulleys... making my car sound like lorry.... difficult to start the car.... even if it does its using hi-cams... idling run mad n engine dies off... a fren of mine open the timing belt cover to check...found out 1 out the rubber piece at the bottom of the cover is missing... maybe drop inside aredy.... also 1 small crank on the belt.... so i dun start the car until its done.... will get a mech to do it at my place 2moro... maybe change timing belt also...
how much is the timing belt ha....
yalar bro... by tomoro i have to kawtim this aredy.... cos i cannot wait to test my new clutch set... hehewirafly said:hope u get ride from this problem ASAP
looks like another 250 abt to 'terbang' aredy...ayell said:wahhh.. sounds terrible.. timing belt ha.. last time i bought mine Rm175
wirafly said:According to wiseautoclub, cpmah dyno result show 99hp on wheel, cpmah, they mention your car auto, is it?
http://s3.invisionfree.com/WiseAutoClub/index.php?showtopic=3479&st=45
cpmah said:When I install in both item in my 4G91 with 4G93 head. The timing run 1.5K, when swtich on aircon rpm go 2.5K, than my mechanic take out the SGTI TB and install the 4G91 TB, all timing work perfect again.
partyJOE said:cpmah... crank pulley install aredy ha... how the performance wit it...
yr mech after put in SGTI TB got tune back or not....
