PS-PowerSport Air Fuel Enhancer
A Simple Way to Adjust AFR ‘On-The-Fly’
The PS. Air-Fuel Enhancer is designed to enhance the air-fuel mixture ratio to the highly modified EFI system engines. It alters the air-fuel ratio by conditioning the air mass signals to the sophisticated fuel computer unit. It is a device, which is ideal for re-mapping of the engine fuel feed controls, especially when the ECU is not designed to handle a level higher than the original mixture requirement. It features a 50% -/+ mixture adjustment of the accelerator position – ACCEL I / II, which will be either at idle or at wide open throttle operating conditions; and an additional 25% -/+ LOW, MID & HIGH rev’ range adjustment for desired performance while the car is being driven.
This AFE device is useful for re-calibrating fuel curve in the even of the use of a different air-flow sensor, larger fuel injectors, ported head, cam modification and an increase of boost pressure or compression to existing engine at higher level of fuel metering.
PS-PowerSport Air Fuel Enhancer Type 1:
- For mild engine modifications
PS-PowerSport Air Fuel Enhancer Type 2:
- For pro. engine tuning
Benefits:
- Air/Fuel mixture ratio correction through 8 fine adjustments over the entire acceleration and rev’ range from original setting.
- On-the-fly air-fuel mix adjustment through simple set-up of 5 control knobs with LEDs indication.
- Provides better engine power and good accelerate response with idle, low, mid & high rev’ mixture correction functions.
- Several options of customized chips could be created to re-map larger fuel injectors replacement and to allow enhancement of the standard factory fuel program.
- Ease of replacement of original restrictive airflow unit by utilizing PS Air-Sensor Converter for higher airflow improvement.
PS-PowerSport Digital Turbo Booster
For Peak Turbo Performance & Efficiency
The ’PS’ Digital Turbo Booster-II [DTB] is a boost pressure management system with digital electronic state-of-technology; offer a user switch-able LOW & HIGH engine power with the push of a button. When the power switch is turned off, the boost pressure will return to original [NORMAL] settings.
The device is equipped with a high-tech. electronic integrated boost sensor to sense the actual boost pressure in the intake system, and constantly changes the internal settings to obtain the most potential boost pressure at all engine operating conditions.
The major advantage of featuring the build-in boost sensor is the fact that it versatile with advances close-loop control, measured the intake manifold air pressure [boost] that are electronically set by the controller unit mounted in the driver compartment, then transmitted to the booster control valve which mounted as close to the turbo-charger as possible.
This is giving a faster and more accurate boost response to enable the waste-gate close longer in each gear at desired boost level - The result is a dramatic improvement in engine low-end and mid-range power or acceleration.
Features:
- 3 switch-able power level –NORMAL, LOW & HIGH
- Easy setting for accurate boost control up to 30 psi.
- Excellent power improvement
- Friendly mounting small controller size – 3” x 4” x 1”
- Suitable for most gasoline & diesel turbo-charged engine
- Compatible to integral or external waste-gate
Normal Boost - both green and red led off
Low Boost - green led on
High Boost - red led on
PS-PowerSport Digital Turbo Booster with PS-PowerSport Air Fuel Enhancer
