rem
rem
for 2,3 days, my distributor kong.... any side effect to my distributor? Do I need to get the MSD? If so, what kind of MSD? Need help, since I alredy change to second hand distributor and dont want it get spoil after 2,3 times rem
rem
rem
..... but vtec turbo manyak syiokkk jugak:stupid:.I just BOT to my B18C type R.... after remrem
rem
rem
rem
Hi guys!!finally i manage to replaced my gear box to manual...but another problem coming..my exedy clutch slip at high rpm...fyi currently im using heavy duty clutch & boosting @ 1 bar..guys need ur help to solve this problem..
change to OS Giken twin plate or go for Ogura super single
Bump: wei Mellon... bro ... how's things .... long time no see u n ur ride ...
hahah i koyak until jual rumah wei..vtec turbo = koyak lorrrrr:hmmmm:
Koyak when u make a wrong.But ok for 60psi of boost hehehehehe.When high boost..everytime overheating.Jo kasi welding la block dgn head hahahaha baru tak terangkat punya.
Bump: Koyak when u make a wrong.But ok for 60psi of boost hehehehehe.When high boost..everytime overheating.Jo kasi welding la block dgn head hahahaha baru tak terangkat punya.
good idea..
...sure i follow one...Koyak when u make a wrong.But ok for 60psi of boost hehehehehe.When high boost..everytime overheating.Jo kasi welding la block dgn head hahahaha baru tak terangkat punya.
follow to boost 60psi?u share this info early ma...sure i follow one...
Bump:
u share this info ma..isure i follow one..![]()
tire presure or boost?
when u play 40 to 60 psi no one uses actuator already la bro.after welding,take out actuator hose,full boost it la ...
Bump:
Kantoi!!
