Pls Advise - Microtech MT4
Qke
Hi,
can anyone share abt this piggyback ecu? Do it has REV/Boost/Speed Cut and MAP Sensor function?
Reliable for boosting up to 1.7 bars?
:wavey:
Hi,
:wavey:
yes the mt4 has it all..
only bad thing about microtech mt4 it is more expensive..thats all..
unless u get used one..
new one unit only is rm2000 no install no tune..rm2800 total..
if used u can get on zth rm1000 to 1200 market price..
Hi Vteckiller,any ways of getting a second hand MT4?
Pls kindly advise...
Thanks
Thanks
find in for sale section la forum...
if u really serious we can offer u best price is rm1700 for brand new unit..
Do MT4 have Ignition harness?
Bump: Do MT4 have Ignition harness?
yes no ignition... vteckiller but you told it have before so i buy your mt4 but then it is actually dont have when i comfirm with joshua from millennium.... i don't think you will forget me right -_-"
yes none...
but can remove airflow..can remove speed cut,rev cut,boost cut..etc...
and can tune injectors by mili second not voltage..
yeah check it out~mt4 is good enuf if depend in many piggy back ecu,no one piggy ecu in maket got build in map sensor bai~but mt4 inside got, very independent ecu,map speed is sure fast then the engine,coz direct control the injector~not cheat the air flow sensor one,depend your self:biggrin:
i'm using Mazda B6T & airflow voltage range 4-9V (technology zaman purba :biggrin:)
if i want to use MT4, can i remove the airflow??
joshua... how match this prise including .. installation n tuning ... also take out airflow... how mush.?
Bump: joshua... how match this prise including .. installation n tuning ... also take out airflow... how mush.?
