cant wait to install my MS tis wed. :)
good luck!cant wait to install my MS tis wed. :)
Dear All,
I bought my MS kit from DIY Autotune can some please verify if my car will be able to start? Is there already a base map in the microprocessor/chip?
Trying to contact cipan but to no avail so if anyone can forward me a phone number (or should Cipan see this message) pls do so.
Thanks.
It would be best for you to contact Cipan, he can make all of this for you.
What engine do u plan on Megasquirting?
Initially when I came here only because I could not locate Cipan, which I have now. The engine I am Megasquirting is a VW KR engine. I am currently at a stage where the hardwear is being installed, the rad, alternator and the a few more bits and pieces. Cipan has already given me a base map just to get the car started and then the fun part begins.....:hmmmm: Thanks for all your helps. Cheers
MS fitted, car running and idling nicely. Booked another session with Cipan for further adjustments.
Just want to say thanks to all that has helped me in the process of going MS and above all a BIG shout to Cipan for his professionalism and patience.... terima kasih.
11.05.08 Cipan saves the day again......
You can choose to buy from DIYautotune. But You make sure you know how to fix it la. Buy from Cipan much simpler , one package cover all.
