aiks shay....i saw the roadblock by traffic thr...din noe u would pass thr
i teach u how to use tat road if u wan go lutong...1st...turn at the roundabout for 1 turn...see got police o not...den also see car infront of u got step on the brake o not..usually when ppl saw traffic they will brake down awhile hahaha
and if u turn 1 round...u will be able to see inside the road got traffic o not..
another easy way apart from pusing the roundabout is to look for white horse with walkie talkie sitting at the roundabout inself..between the flowers and tree..
I bought a used 350z (2003 version) in Feb'13. At the beginning, there was a problem with the engine vibration and the mechanic had rectified it by replacing the ECU.
Hi all.I just installed a cheap 2 way alarm at nearby acc shop.first time went there,after finished the installation there was no problem.later went there 2nd time to fix relay for trunk release and after that my ABS...
hi gang, i have been trying to fix up my engine for quite some time with little trial and error method but still i cant find out the problem and even sent to most mechanic and they all scratch head
was riding a...
