Looking for suggestion for FTO Specialist
Mar 12, 2021
2
33
Hey guys Im new here,
Just got a 1994 Mivec Mitsubishi FTO a few days ago and would love to know from you guys if there is any workshop or specialist workshop you would
recommend nearby Shah Alam area for the particular car.
I had try google searching and fb post searching but fail to find one.
Thanks every sifu in advance ya
Reactions: DR78
no such thing as a FTO specialist la bro. Mitsubishi 6A12 specialist got la and there's plenty bro. The one i know is in Puchong though. What do you want to do?
FatBoyMeetsCoffee
2
33
Hey bro, just want to let him examine it thoroughly and see is there any parts that are faulty .
Anyway mind sharing the location of the shop in Puchong? Thanks ya bro
ixeo
4,788
3,080
KL, Malaysia
DR78
549
54
5,028
subang
Mitsubishi FTO no need specialist. Very easy to fix. Similar engine to perdana so any mechanic can fix it. Plus the undercarriage all similar to Proton for example under arm and uses Waja I think. All mix and match with proton spare parts. Don't get cheated by mechanic that tells you FTO spare parts hard to find. Semua proton parts can use except interior trims etc
Reactions: minibeany
lsm1991
1,469
185
thats not exactly true.... far as the gpx goes im somewhat familiar, lower arms can kacuk wira (one of the models as well i dah lupa exactly which) but positioning isnt 100% perfect, waja also can fit, also lari abit. undercarrige is similar yes, actually if u main swap, whole front subframe can swap in evo 456, its a match, middle section, if not mistaken satria bars fit, rear also another model also dah lupa, its been a while.
engine, well if u have the mivec theres actually alot of bits thats model specific the entire head timing belt all x sama.... things like the ac compressor can mix abit with the ck compressor, just swap over the mounts. radiator if u nak swap in evo or tall ones, u can space it, or some ppl cut the hood to make clearance. the other bits yea cankacuk other mitsu models if x salah
Strategic Vision has released its results for the 2007 Total Quality Awards, and the final tally is a bit surprising. For the first time ever, Hyundai has risen to share the position of having the most models leading a segment, along with Nissan. Both brands had three models with the top Total Quality Index (TQI) score in their segments, including the Hyundai Azera, Entourage, Santa Fe and Nissan...
