Save ur money bit by bit. Since now u happy with fc just drive as it is.
Get halfcut, start from there buy bit by bit on "upgrades".
IF u think save enough, then u can choose ur poison or better car.
As mentioned before, my working environment is construction site there is no point of me to buy a better car to get wasted. Except I chg to a pick up that is another story. Hahahahahaha
lemi enhance swee's suggestion...
wira keep, daily driver.. just needs to be able to move reliably..
2nd play play car~ a car made to play
See my profile picture? That is my 2nd car.Hahahahaha.
Although most of the time is my dad driving. I think for now I just make the wira more reliable then only find another car to play in the future.
Like.....a 1jz e36? Hahahahahahah
Starter relay. I recall autos have a weaker starter than manuals or was it the other way aroun.
Not wiring old, resistant high, then need relay? My VR and Hyundai all the years no need relay then couple of years back both also fitted with relay, VR 28 years now and Hyundai 23 years.......lol
I was about to mention this. Once the half cut taken apart to sell by parts the prices are higher. If need only a little parts, of course buy parts, but if need long list, better compare prices first
Buy lah.....Diesel is a whole new exciting world. Get one with VGT or VGS. Amazing torque. I would suggest the triton as seating in the rear is very much like seating in the rear of a small car with just slightly fitmer ride. Front is car-like. How pickup has evolved.....
if my Wira steering wheel has so 'emptiness' about 1-2 inches before the wheel actually react. What could be the problem and how to fix it? Prefer to have those quick response once the steering turn left/right.
Have you checked your steering rack bushes? They can be a pain to replace though
My mechanic wrap a thin sheet of rubber (I think those bike or car tubes) over the old bushes and clamp that on. Was good until I sold the car years ago......lol
steering rack bush worn out. becareful when changing to those silicone ones. sometimes it's not perfect fit. need to add extra rubber like @vr2turbo said.
Thanks... i'll ask the mechanic to check and maybe replace if that is the case.
If have to add rubber, then that makes those silicone bushes kinda pointless
Can check yourself. Have someone turn the steering and you shine a light on the rack to see if there's movement
Wira update
I had juz survey whole set of Gearbox wira 1.5 cable is RM800
Installation ia RM400 (abit costy
They say they accept trade in my auto but they need to try does it have any problems then only quote me the price of my auto box.
May I know Cable & pump type any difference on daily usage?
some silicone steering rack bush are crappy thin. when tighten the silicone expand and cause the rack to still move a bit. hence need to check properly before buying the cheap silicone one. also, for silicone when installing, always clean the rack area properly from oil cause that will also cause the rack to move. hahaha
