Thanks man for your continous support. I'm appreciate it.Wow.. you gonna make it into a show car with all that anodizing.
Very nice
Yaloh, the built really nice......Wow.. you gonna make it into a show car with all that anodizing.
Very nice
View attachment 572707 View attachment 572708
Spotted some issue on the fiting. Two front bolt hole not fitting nicely. Need some adjustment on the Turbo Flange.
Those old flange are original came from stock GSR 1.8T. And the flange of banana are custom made. Mechs said, better to adjust the old turbo flange rather than banana as banana flange made from a quality and thick steel.flange is t25 and turbo is t3?
I see. That's new thing for me. Thanks man for your shared info.yup... just send the turbo exhaust housing to change the flange into t25 size...
"Txx" xx means bigger number is bigger flange (which directly means bigger turbo usually)
Thanks man :)Wow!...Nice....![]()
I'm using Injectors from Supra 1JZ running 355cc. With the Sard High Performance Fuel Pump run at 265L/hour.Wow... nice so many new parts, btw how many cc injectors are you running? And how much boost are you planning to run with the td04?
It was my dream since long time ago. Even thou kancil is a small car.wow.. big budget build!
I wanted to build a L2 Kancil a long time ago. Stripping down the Kancil 850 was so easy and barely ever needed a jack. I could almost lift the whole engine myself. LOLIt was my dream since long time ago. Even thou kancil is a small car.
Ok man. Noted with that. :)I wanted to build a L2 Kancil a long time ago. Stripping down the Kancil 850 was so easy and barely ever needed a jack. I could almost lift the whole engine myself. LOL
Be careful about those SARD parts ya. Those are almost 90% confirmed not original so in terms of reliability you need to be diligent in checking.
