Yup, Manual. He had amazing control of his car and familiarity of the road conditions helped a lotManual?
They forget to check between his legs. Balls of steel.
I guess thats the same Myvi that overtook my brother in a manual Neo CPS. That driver really knows the road as he position his car nicely for each corner.Yup, Manual. He had amazing control of his car and familiarity of the road conditions helped a lot
No,no....75 profile tires built to handle potholes.TAKUMI? He use the gutter technique cause he knows where it is. But then the tyres probably 75 profile tyres cause Malaysia gutters are deep deep longkang
Eh? You know who I'm talking about?I guess thats the same Myvi that overtook my brother in a manual Neo CPS. That driver really knows the road as he position his car nicely for each corner.
Sorry for the late reply lolWasting time. And money.
Exhaust always “feel” fast because of the sound. End up still damn slow.
Make no mistake, feeling fast and fast is very different.
Don’t waste time siok sendiri. Also, exhaust gains (extractor + exhaust system) usually at the peak RPM. How often you drive at peak?
My dream to place in a 2zz in vios lolhmm no turbo or supercharger mods ehh....
i think the most practical will be a 2zz conversion
(not saying cheapest, just practical)
Thanks for the suggestion and advice, helps me a lot by asking what I wanna ask lolMy 2 cents.
- Since this is a shared car between you and someone else, don't bother modding for power. Make the car handle better with a set of good aftermarket suspension, a lightweight set of rims, a good set of tyres, lightweight larger brake calipers and rotors, sound proofing and better headlights would make the car nicer to drive and possibly even easier to drive.
- Don't add a ton of UR bars too, understand what each bar does and only decide which bars you need and install those only. Adding everything will stiffen everything and that may not translate into a better drive.
- Exhaust mods at this point is pointless. If you do big mods with your engine then change exhaust to match, sure. Do nothing and just change exhaust - waste money. Stock is good enough la. 4-2-1 or 4-1 won't make financial sense, it's not like your car currently is slow. Vios' in general have great pickup and have great FC. They just don't handle well most of the time.
- Changing to a large TB will have some downsides. If you're unlucky you'll get "on/off" throttle. In my own experience with Myvis, the 2nd gen has a larger TB than the 1st gen and I have both. Swapped the two around and the response was sliiiiiiiiiiiiiiiightly better on the 1st gen Myvi. Not significant. The 2nd gen one has larger valves and all - so if I swapped the head then I'd have better performance. But I wasn't going to do that on a pointless minor performance upgrade. The head gaskets cost more than the performance gained.
Like I said - the Vios is a great performing car. It's not gonna beat any land speed records or outrun a R35, but it's not a slouch and drives pretty well. With a good set of suspension, brakes and rims+tyres, you'd have a pretty nice car to drive around in. Learn to drive the car fast bro without the performance mods. I know a guy who drives his Myvi 1.5 STOCK (except for 15" rims + good tyres) faster than a lot of people going up Genting. In fact he's so fast people driving way more powerful cars have claimed he has a modded car until they see his tiny little exhaust pipe and stock engine bay.
Hm, if wanna say the often RPM, i cant really answer lol, cuz i always accelerate hard when the road is clear, mayb 4?
Haha
+1 , lightweight wheels and good tires, brakes, bars...etc = safetyUpgrading to larger TB will increase air intake but again as Ixeo mentioned, the gain is marginal only. For NA engines, you need to do almost end-to-end mods from intake to full exhaust plus some remapping to start feeling a decent gain and by then you'd already spent quite a lot of money. Since your car is an auto, that's even worse because what ever gain that you get will get masked more by the sluggish automatic. I'm not saying you should not mod, but I guess you should not set your expectation too high.
I also agree with Ixeo that the best mod and the easiest you can do for your car is get the best high performance tire available for your size. That will improve your car handling and cornering significantly. Then slightly stiffer suspension with thicker antiroll bars should be enough to help you have a bit more fun in the car, plus feeling more safe and stable in the process too. Next should be braking, especially if your stock brakes are not so good. Handling and braking are more important mods than power. Only after you got those sorted out then only start thinking about power mods.
Like earlier days, many talk of improving engine for more power, never thought of handling and especially stopping......lol+1 , lightweight wheels and good tires, brakes, bars...etc = safety
Your rally spec one still around, right?actually i do agree on that... many people thinking upgrading power only...
but me...i do enjoy driving my satria back then more than my current car.... especially when weight plays major factor in handling...
yup...
on jackstand waiting for total rebuild... lol
I remember quite a few years already.....Standing on the jack how many years already hahaha.
his car isn't a daily la.. and his is for racing!Is Izso racing him to see who’s car stand on the jack longer? Lots of catching up to do.
He is still rubbing it in.......lolhis car isn't a daily la.. and his is for racing!
Thought he's getting an auto transmissionhis car isn't a daily la.. and his is for racing!
cheers
