Proton brake light bulb burnt very common.......lol
The first pic got burnt one side. But the second pic din't.
this week i saw lots of myvis third brake light not working. people never check brake lights.
Means both bulbs burnt.......lol
Hmmm, so for these older type Wira, the 2 bulbs can work as brake lamp? While some of the newer ones have only 1 bulb that works for brake, 1 more only for night lamp?
Normally is one bulb with 2 filaments. 21w/5w....![]()
Which means they can double up as brake lamp and night lamp at the same time?
Usually are like that even VR lights are like that. Some cars of course have separate night light and brake light especially newer cars fitted with LED.....
Mine got 2 bulb but not sure how to check if they are dual filament or not.
Need to taken out and see loh!
Single filament....5w for tail light, if 21w for signal light, some signal bulb comes in orange color
Twin filaments...... 21w/5w for brake/tail light
Nope. Mine got 2 light bulbs in there. big one for brake light and small one for night light like this:
https://preview.ibb.co/jG1Lua/IMG_8179.jpg
Pardon the rust. This was before I clean it. You can't get this socket anymore at spareparts shop.![]()
As per bro. sanekit photo. Small bulb is tail light, big bulb is double filaments for tail and brakes....
As per your photo, signal light on top.....lol
Yes. and the big bulb is outside. signal inside.
For those fully lit even on braking, means the small bulb should light up as well? Because the small bulb is on the inner side.
Located somewhere else then.
I thought signal is on above these lamp? :hmmmm:
sorry. the small bulb is the night light. big bulb is brake light and night light. so at night, both supposed to light up and the big bulb 2nd filament will light up when braking.![]()
Heat shield with CAI for my Apexi . http://i3.photobucket.com/albums/y61/Ayok/HScwCAI.jpg
