hello there,
I own a 2002 iswara(M) but have trashed the car to the maximum. I have clocked 300,000km. the absobers are totally gone i guess (when push the car down, it does not come up back...hehehe)
i dont want to change car since this car has sentimental values for me. i have about rm 6k to get my saga back to action.
I was browsing about upgrading my engine. does a 4G91 dohc fit into my iswara. If it fits, do I need to modify the mounting?? Will JPJ give approval. otherwise which other engine gives good power to fuel efficiency for a saga. I am looking for a low maintenance engine with just sufficient power (something like a wira 1.6). it should give me good fuel comsumption as well.
wanna masuk wat sport rim? i heard jrd is paling problematic? can recommend any brand? i wanna fit in 15 inch lah... What tyre gives a quiet ride as well as stability.
how bout absobers? is there monroe sensatrac available for saga? or should i just use the kayaba type again? should i choose the oil type for the front ones and the gas type for the rear ones?
i just need comfortable ride with minimum noise. is there any sport springs that will give better handling without compromising on comfort. APM sport springs bagus tak? or gona stock paling bagus?
does changing the extractor to the 4-2-1 type effect the fuel consumption badly. i heard the powerzone ext. is the best for mit. cars.
do i need to change the exhaust piping, muffler , bullet, tabung semua kalau fit in 4g91?? anyway i wanna change the tabung. the stock tabung sudah bocor dan welding.....
how bout clutch plate and gearbox. kena tukar ke kalau masuk 4g91? drive shaft also?? atau boleh pakai 1.3 without comprimising on the car performance.
one more thing? is there a 3 point stabilizer bar for proton saga rear and front?
brake system; does the wira 1.6 rear disk fit for iswara rear?
well sorry a lot of question. i want to improve my saga since it has sentimental values. no need to answer everything if possible just share ur ideas for a few of my questions..
thanks in advanced...semua sifu sifu kereta
