Sanekit : Wah... your problems never ending man. But it should still be under warranty since the rebuild right?
Yeah that's what I thought too. I also recall one batch of the Putras had really thin front ARB, even the Wira SE stock one was thicker than it. Wira SE stock was 20mm if I recall correctly.
23mm I doubt was a standard size. That's the aftermarket GSR thickness ARB already
Bro Iszo, I don't think the C99s come with 23mm front out of factory, probably 20mm. I remember those Putras doesn't have 23mm front, so I assume the Wiras are the same too. Only first batches of the 1.6s have 23mm front right off the bat (91-93 Lancer/Mirage models)
Wow thats hell of a journey and scenery hahahah took you how long to finish the trip? do you gradually increase the speed or aggressively? i think i will do it the hard break in way...just now quite sure how to do it properly yet. Will need you to further explain in TT hahaha
I read it somewhere 1999 and onwards putra runs a 18mm front and 13mm back before 1999 they were 23mm...Wira/Satria 1.6 and 1.8 runs a similar (23mm front) setup
