I think need panel shop to pull it back in place since not adjustable...
This car accident was by previous owner?
Previous owner was my brother. The driver was me, he was sitting next to me. One ah beng wira racer was tailgating us quite close. A 4X4 isuzu suddenly came in to the third lane from the left, manage to avoid it but still hit the side a bit. Brakes was ok but the other wira brake locked and pushed my car to the center divider. Lucky we didn't go into the ditch before the interchange..![]()
Bro vr I think if the wheel hit something during the accident, it could be the subframe slightly "kemek" also...but his case is diff with mine I suppose since he's is closer to the bumper while mine is closer to the car bodyI think need panel shop to pull it back in place since not adjustable...
out of topic abit, usually whats the preferred break in method? hard break in or no high revs until 1k milleage? anyone kind enough to shed some light? :hmmmm:
Yeap it's the c99 dohc, so it should be 23 mm front and 13mm rear is it?
There's so many theories and concepts. What I do is when my engine is all done up, I pour in mineral oil, relatively thick like 10W40 or something, drive down to JB, drive back, drive down to Penang, drive back, change oil.
Speed I keep it between 110km/h to 160km/h, rotating between the two extremes.
Slow and steady break in will guarantee those piston rings to be tight-as-f*ck and once it sets, it'll stay tight-as-f*ck so you'll have shitty FC, shitty power and there'll be nothing you can do about it.
Kinda like my current car, previous owner drove it like a pussy and now it's max FC is 10km/L when others can get 12-13km/L.
So don't pussy foot it. The key isn't only just redlining, it's consistency. But that's my opinion la.
23mm I thought is GSR thickness? I didn't know C99 was that thick too. Dang!
Bro Iszo, I don't think the C99s come with 23mm front out of factory, probably 20mm. I remember those Putras doesn't have 23mm front, so I assume the Wiras are the same too. Only first batches of the 1.6s have 23mm front right off the bat (91-93 Lancer/Mirage models)
Looks like we got new information and a little history there......I would say instead of increasing the engine's power, better take the look at the chassis dude
and of course endorse your engine first lol
I can recommend you to a guy name Sureen in USJ 1. He did all of my car's bodywork throughout the years
Are you coming for the DIT? Engine endorse will be done end of next month. The chassis not gonna bother with the endorsement coz engine mount not affected. Just the car runs to the right a bit on rough roads.
The sluggishness is what bothering me most. Just found out my gearbox have some serious leak at the oil sump pan. There's a leak on the engine oil sump pan before, gearbox leak is new coz just had it overhaul. Gonna go to gearbox workshop to get them check it and fix.
Sent from my iPad using Tapatalk
50/50 for the DIT because need to check my flight details again haha
GB leak? Better get it check before any more major issues arise.
Hey shinjite, check out this blog http://thespfiles.blogspot.fr/2006/07/got-roll-upgrading-anti-roll-bar.html i read it from here![]()
Ahh I see then if could be wrong too ill just measure it when it's out to see is it true hahahaI have seen that before. The thing is....my mechanic's 1.6 Satria doesn't come with 23mm front. He has to upgrade it. SO some of them is not standardize.
anyway manage to meet him up with his mother"s MYVI..power window spoil LOL...and chit chat abit and then he mention...
