arnd RM2.6K
JGE_4G15 said:then you know wats the cost for Tien adjustables for wira 1.5?
JGE_4G15 said:SkYwAlKeR...any idea how much it cost for both front and back?
SlipStream said:The sounds goes like "tok tok" ...i think it can be more accurately categorized as knocking than pinging. I get those from the front right suspension. Some of those "eiik eiik" kinda sounds as well...from the back suspension. These sounds could not be reproduced by bouncing the car up and down... been doing that the whole afternoon at the workshop. The mechanics are at a loss too. The absorbers are quite new..confirmed not damaged, so are the arms and suspension mounting. Headache.. headache :cry_smile:
. I read about all the comment here and izzit changing to lowered absorbers@short stroke absorbers will solve the probs? BTW,i'm driving Saga FLX.Hi guys and sifus,i just install a set of lowered springs paired with the OEM absorbers.Everytime i drive thru bumps or rough roads,there's "hissing" sound from the front part of the car.The sound is quite annoying. I read about all the comment here and izzit changing to lowered absorbers@short stroke absorbers will solve the probs? BTW,i'm driving Saga FLX.
its normal, even bmw's has that hissing sound when going over bumps
I guess I shud change to lowered absorber @short stroke absorber to get this solve..for me the sound kinda irritating![]()
also your undercarriage bushings will worn out faster.
currently using Improve Lowered Springs.any comment on that brand??this is the 1st time i lowered my car.. the past car i use oem springs
From what I heard, sports springs and stock long stroke absorbers don't go together. You can opt to change it now if have budget if not use until kong only change while planning on the budget for more suitable absorbers. Reason is, your stock absorbers are gonna kong soon because of the sports springs since is not short stroke.
What kind of sports springs u using?
Not entirely true. It depends on the spring rate of the springs. If the spring rate is not too high/hard then the std shock can still cope with it. It might reduce the lifetime a bit but can still last for a long time. I've been using lowered springs with std shocks all the time and no issues.
