Matching sports spring with stock absorbers ...appreciate feedback
marv3
496
57
528
Hi Sifus,
I am new to the car mod scene. So any advise and feedback is greatly appreciated.
I am actually planning to lower my car. Im driving a 408T. I manage to find a lowering sport springs that can fit my car. It is call H&R.
My question is:
Is this brand good?
How is the spring rate? Very hard?
Will is spoil my shocks? Coz i read earlier that if the springs is not too hard, it is still ok to the shocks.
You feedbacks and advise are greatly appreciated.
Thank you
6UE5t
6,000 RPM
6,756
1,300
Hi Sifus,
My question is:
Is this brand good?
Thank you
I think it should be fine. H&R is a world famous suspension brand, just like Eibach. Many Euro cars sport springs are made by this brand.
neo83
318
9
518
Johor Bahru
the best is still adjustables.
local GAB or any other generic brand will do.
which one is batter HWL,GAB,Zerone??
---------- Post added at 11:41 AM ---------- 6 hour anti-bump limit - Previous post was at 11:36 AM ----------
So still best to either get a short stroke Absorbers like KYB RS or adjustables right?
is it KYB RS is adjustable?
or not..
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
or not..
HWL for comfort, GAB slightly hard, no comment on zerone.
KYB RS is sport shocks non adjustable.
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
or not..
KYB RS Pro is adjustables. KYB RS is just a sports absorber. Now got SR Series which is also sports absorber if IINM from KYB
Jul 5, 2014
hi bros,
need help.any suggestion adjustable for persona. hehe. is it ok to fit larger rim after adjustable installation.
tq
beatnik
924
74
3,028
Hi Sifus,
My question is:
Is this brand good?
Thank you
It will be stiffer. Depends on your tolerance, you may or may not like it. H&R/Eibach is best if paired with Bilstein B8 absorbers.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
i think maybe 17'.
If u are prepared for super hard ride and higher tyre cost then got for it.
With 17 rim u will have lower profile rubber which will makes the ride a but harder. Then the adjustable which is always harder than stock will makes it even harder.
If u dont mind it then go for it. Depending on your choice of rims, your can can look super cool and a bit underpower if u opt for cheap rim as they are heavier.
faruck
861
46
528
selangor
if eibach spring can masuk 2jari n comfortability acceptable for me because my accord n f30 use eibach..h&r 1 jari n stiffer..bcause h&r spring shorter..but theres some people complained bout h&r..they said sometimes they heard the spring like tendang when corner..
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Spring tendang means it moves or spins on its mount.
I exp it before but with stock spring and absorber.
Solve it by removing the absorber, clean the mount bot on the top mount and absorber, clean the spring where it will sit on the absorber. Reinstall back.
Do not use lubrication fluid as it will make ting worse.
faruck
861
46
528
selangor
i know bro..but this is not the case that the spring masuk x ngam..it happens because of the spring is too short..if the spring masuk xngam it happens a lot to those who just changed their ori spring to sport..dat one because the pomen from hugo klang shop pasang..they usually follow their heart oni when pasang barang.. :nurse:
marv3
496
57
528
Hi all,
Thank you for your feedback and advise on the H&R. I think im ok with it being stiffer. But my concern is that it is too short to the extend that it expedite the reduction of the absorber's life. I understand no matter what springs, once you change springs, the absorbers life will be reduce. I just dont want it to reduce so fast. Hahahaha. So thats why i asked if H&R will match my car's stock absorber or not? =)
But now im abit concern coz of the spring tendang issue....Hmmmmmm
Hi all,
Nope. H&R Springs are shorter than stock so your car will be lowered. It'll probably half the lifespan of your stock absorbers.
Suggest you look up Koni + Eibach Prokit as well. Koni has a pretty interesting valve system in their shocks
<img class="alignnone size-medium wp-image-31255" src="http://www.zerotohundred.com/wp-content/uploads/2012/06/sti_front_2-600x400.jpg" alt="" width="600" height="400" />
While the BRZ was battling it out it the Super GT GT300 class down at the circuit, Subaru had also brought another car down to Sepang; not for the race, but to unveil their all-new Subaru WRX STi 2012 into the Malaysian market. To those that miss the Subaru’s old 4-door sedan layout, your prayers have not gone unnoticed...
