2011 myvi 1.5 engine block
me kena smoke by super silent kelisa not long ago...
i was on the fast lane during overtaking long que middle lane.....the kelisa coming really fast from behind...estimated speed more than 160km/h at that time :driver:
Especially if it smokes larger cars like Camry, Accord or Teana. If lucky, maybe can smoke C200 or 320i also.
The expression of the Benz and BMW owners when they got smoked by Kelisa :confused:
That's priceless.
Teana pick up maybe lose, but top speed against 2.5L V6 a bit hard for kelisa YRV turbo gua?
Not sure never driven any of these 2.
maximum speed for kelisa is 160km/h. Unless he changed his meter :rofl:
boxy kenari can go more than 160 confirmed...never tested kelisa...should be higher...
Kenari is more scary than Kelisa going at 160km/h man. The whole car height is all out.
U mean the car can travel more than tht speedometer actually? :stoned: Damn!
on that kelisa that overtook me...probably yes...
maybe thats what ppl call "meter ketuk dinding" already over the scale :p
If I recall reading somewhere, the Myvi 1.5 engine isn't going to be a perfect fit onto the old Myvi 1.3 body. The engine is slightly taller so the hood will hit the top parts of the engine or something. Need modification on the mountings I think
Sell the 1.5 block, get a K3-VET. No comparison man, the K3-VET has a small turbo, 3000rpm already full boost, perfect for city driving.
Kelisa turbo :rofl:
Teana 2.5 I dont know can win or not. But Teana 2.0 I think can.
Meter does not determine the top speed, isn't it? Like many cars in Japan have a meter that is until 180kmh. Even 350Z and R34 Skyline GT-R also meter until 180kmh.
Kelisa turbo :rofl:
Not sure whether can add additional speedometer or not. Some can change unless got half cut for it. Like the 4AGE TRD AE86 :biggrin: Normal one have to change to TRD ones.
I think got extra external one gua. Not sure.
Well, usually the tuning division of respective car companies have alternative speedometers available for their cars. Like NISMO, TRD, Mugen, Ralliart, Mazdaspeed, STI and etc
Put 4age.. :D...imagine myvi with 1.6cc 165hp...feell it...
Sent from my GT-N7100 using Tapatalk HD
---------- Post added at 06:42 PM ---------- 6 hour anti-bump limit - Previous post was at 06:28 PM ----------
Yes, only A/T available but it comes with tiptronic. so can still shift gears.
Might as well save up and transplant K3VET Engine, but have to take brakes and suspension modification as well.
Its not tiptronic gear its Steering shift attaching 4 speed automaticDisplacement,here k3 vet full spec
Body typeMV&1Box
Drive FULL 4WD
TransmissionSteering shift attaching 4 speed automatic
Displacement, cc1297
FrameLA-M211G-GQSJ2
Price of new car, thousands yen (Tokyo area)1744 (~$14500)*
SPECIFICATION (SPECS)
EXTERIORExterior dimensions (LxWxH), mm3765 x 1625 x 1550Interior dimensions (LxWxH), mm1745 x 1335 x 1270
Wheel base, mm2370Treads (F/R), mm1380 / 1360Ground clearance, mm145
Curb vehicle weight, kg1000Gross vehicle weight, kg
Seating capacity, persons5Doors number5Min.turning radius, m4.3
Fuel tank capacity, l37
*ENGINEDisplacement, cc1297
Engine modelK3-VET
Max.power (Net), kw(PS)/rpm140 ps (102.97 kw) / 6400 rpm
Max.torque(Net), N*m(kg*m)/rpm18.0 kg*m (176.52 N*m) / 3200 rpm
Power density7.14
Engine typeWater cooling serial 4 cylinder DOHC16 valve IC turboEngine informationHorizontal ranging DVVT
Fuel systemEFI (electronic fuel injection)
TurbochargerTurbo with intercooler
Fuel typeUnleaded regular gasoline
LEV system (Low emission vehicle)Yes
Compression ratio8.5
Bore, mm72
Stroke, mm79.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km6.9
---------- Post added at 07:06 PM ---------- 6 hour anti-bump limit - Previous post was at 06:42 PM ----------
Body typeMV&1Box
Drive FULL 4WD
FrameLA-M211G-GQSJ2
Engine modelK3-VET
Power density7.14
Bore, mm72
Stroke, mm79.7
Final gear ratio
K3ve 2 n/a spec.....Daihatshu Storia Touring & Toyota Duet 1.3s model
Engine model K3-VE 2
Max.power (Net), kw(PS)/rpm110 ps (80.91 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm12.8 kg*m (125.53 N*m) / 4400 rpm
Power density 8.18
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information Horizontal ranging DVVT
Turbocharger No
Fuel type Unleaded regular gasoline
Compression ratio 11
Bore, mm72
Stroke, mm79.7
Final gear ratio
Either is kelisa with myvi engine or K3vet.. sat on my frens kelisa K3vet.. damn.. the car like no weight.. step on the pedal only the meter just go smoothly to 120km/h without any effort.. i believe it can go more than 160km/h.. maybe 200km/h depends on the car handling and driver's guts..
Can install HUD display/RSM or speed meter..
