ic ... having idea about this .. ehhehe
custom .. :D
acceptable camber should be lower than 1°..i m wondering what is the acceptable figure for front chamber? need some explain as my tyre makan dalam oredi....![]()
even with 1°, it wil makan more..
if u always travel hiway, better for the camber to be 0°, makan rata...
but since perdana cant adjust the camber without some extra work, u are stuck with the camber ° now.
to adjust camber, u can press or pump the knuckle, or install adjustable upper arm..
i pressed my knuckle at a tyre shop in Jalan Penyelenggara U1/73, Glenmarie. coordinate is N3.0821, E101.5559.installed adj upper arm before...but weird sound came out. very annoying la. so now need find shop to pump knuckle. Neuro, where u did pump your knuckle before?
