Proton Wira Check Engine Light
cvkit17
2,884
1,354
Dear Alllllllllllllllllllll, :listen:
My sis's Potong Wila (2001 model) itu CEL illuminates and I dont know what is the source of the problems. It does not lit all the time, but it will suddenly lit while driving, or sometimes suka suka when I fire up the engine. :stupid:
Few problems encountered when the CEL comes on:
1. Car will jerk like you got a faulty spark plug. For a period of time, it jerks when the RPM is above 2k. If I maintain the RPM less than 2k, it drives like normal. And then after some time, say, 10minutes the car doesnt jerk anymore even if I rev up to red line.
2. My sis encountered that when she adjusts the AC temp, the CEL lit. Encountered this twice.
3. I was once driving the car, and the CEL suddenly lit. Because I was in the middle of the road and the car jerked like hell so I had to pull off the road. I switched off the engine, waited a while and fired it up. The first time I fired up, the engine did not start. I then turn off the circuit and pulled the key out. Unexpectedly, the car alarm went on :hmmmm: so I disabled the alarm and tried to fire it up again and I succeed. The CEL was then gone. :confused:
4. Sometimes when there's CEL, restarting the engine doesnt work and it's still there. Gonna restart a few times.
I brought the car to my mechanic fren and he told me the prob is either the coil, or the ECU settings. He reset the settings and it seemed to work, but it came back like MIB shortly after a few days. :bawling:
I went to another workshop nearby my office and the mechanic claimed that the problem is with the Throttle Body and there's some error in the settings too. So he changed the TB and reset the settings again, and it seemed to eliminate the problem. But again, the problem came back but this time is after some time...a few months. So I went back there and he cleaned the TB and cleared the errors in the settings....but to no avail...:banghead:
Have anyone encountered this before? I'm wondering whether is it sensors that are faulty...can anyone help? :adore: TQ and muacks kaw kaw
**shit =.=" i posted wrong thread at the wrong discussion page. Can any moderator move this thread to "Car Problems", or teach me how? Soli ~.~"
EvolutionZ
5,000 RPM
5,025
1,448
bro,
yr wira is running on mpi (fuel injection) engine? if yes, maybe u could check the O2 (oxygen) sensor....
7,514
wira with mmc ecu or siemens ecu? If siemens ecu have troubleshoot according to obd scan...
If mmc probably the maf sensor near air filter was dirty...open it and remove from car,then spray and clean using electronic contact cleaner..
nyantong
192
50
Can you find out what exactly the fault code is? I suspect it may have to do with either the air flow sensor, throttle position sensor or throttle body. A low pressure fuel pump or leak within the fuel system can also cause the engine to stall.
cvkit17
2,884
1,354
The car is running on EFI , with Siemens ECU if not mistaken. I'll clarify this with the mechanic and ask him to diagnose it again and if there's any faulty code, i'll note them down this time. Was a mistake I dint take note previously. I'm actually thinking of cleaning the MAF sensor also..will ask the mechanic to remove the MAF and we'll see whether is it dirty or clean. I dont know whether did he cleaned the MAF previously when he cleaned the Throttle Body. This time gotta make sure that the MAF sensor is clean, hopefully that I can eliminate the possibilities one by one. Wish the problem can be solved by cleaning the MAF sensor >.< thanks ya'll..keep u guys updated. Will go to workshop this Sat
arsengal
18
503
Hello, new people here. I was googling about Proton CEL and suddenly this thread comes up, hence my comment here. So cvkit17, you're not alone in this :wavey:
I've encountered this matter too several times. My ride is Wira SE(05). My car had the exact problem like yours. First visit to the mechanic after it happened, they said there are two problems; the MAP sensor & the total body. Since the total body was quite expensive (RM500+), I decided to only change the MAP sensor(the sensor was broken liao) and get the TB cleaned. A week after that, same thing happened again :stupid: I went to another mechanic, got the car diagnosed and he said the TB problem dy. So, no choice for me, I had to get it replaced. And they also reset the ECU settings of my car. But just two days after that, it happened again, I got furious liao :mad: and straight away went back to the 2nd workshop with the CEL still illuminating. They straight away plug the computer in, but no errors were detected. So they didn't do anything. It didn't happened anymore after that for 2/3 weeks. But just yesterday, while I was firing the engine up, it happened again. I'm so clueless on what the real problem is.:hmmmm2: one thing I notice is that when it happens, the engine is suddenly underpower. My RPM is like less than half of 1K.
Anyone can actually give an idea on what is really causing it? Thank you
7,514
try check crank sensor....
that was really problematic child because the wire sometimes pinned between timingbelt cover and damaged.....
cvkit17
2,884
1,354
Thanks for sharing and lets solve this thing together bro. It is dangerous when the CEL comes out in the midst of driving. The car loses a lot of power and shake like riding a robot horse. Luckily I manage to pull over when it happens but I had a few close call.
My dad took it to Proton service center yesterday and they said it's the TB. My TB is new (less than a year) and I'm pretty convinced that the problem does not lie within the TB. I shall be seeing my mechanic this Saturday and he said he shall check the sensors and spark plugs as well. We'll see how.
---------- Post added at 09:37 AM ---------- 6 hour anti-bump limit - Previous post was at 09:36 AM ----------
Good advice bro..shall get it checked too this Sat
7,514
and one more thing....
the o2 sensor at exhaust also need to be checked
arsengal
18
503
Yeah, if you did get the true solution of this problem, do share here okay bro :shakehands: yeah, seems like TB doesn't solve the whole thing. I got mine changed as well, & I'm sure its a new one, but still that CEL light goes on, hmmm. There is one time I was cruising at 110km/h then suddenly the CEL came on & my engine doesn't respond to the throttle. Luckily I managed to safely stop at the side of the road.
The mechanic checked my crank sensor as well last time, but he said that's not the problem. I'm suspecting the O2 sensor at the exhaust as suggested by the others here.
Do give the results back okay bro
cvkit17
2,884
1,354
Hi all I've returned from workshop, but not the one where I changed my throttle body. He can't check my car that day as he has many cars to deal with. I went there too late I think...so I took the car to one of my friend's workshop and he diagnosed the car and found no problem or any faulty code at all!! He told me the problem might really be the throttle body, or the electronic chip that is controlling it. He suggested that I bring back the car to the mechanic where I changed the TB and have him check the electronic chip and the TB itself. Sighhh
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Just giving my opinion through experience....
I can be wrong bcos im using a totally different car, not Proton Wira...
2 items you can consider checking...
First the exhaust sensor..
In the case of my car the CEL light appear when the exhaust sensor is faulty..
Secondly...
Please check the engine oil pump....
If its not working properly, the CEL light may also appear.
Hope my opinion can be helpful...:listen:
punk
360
76
Negeri Sembilan
My experience on crank sensor svdo satria..
the symptom:
1. Hard to start the car, need few times crank..
2. change starter, battery but still hard to start..
3. driving highway above 90km/h, the check engine light will light up but the car no problem still can drive..
arsengal
18
503
Hmmm, same as what happened to me. There is no problem or faulty code detected. But still my sense is strong saying its the O2 sensor, sigh but if that's the problem, it should appear as a faulty code during the diagnose. Or it can be checked just by looking at it? No right?
cvkit17
2,884
1,354
If we diagnose it just when the CEL comes out...sure we can know what the problem is..but it would be quite dangerous to drive.
7,514
dammm... been helping our friends here while my car also giving CEL problem.....
since mine was 1.6 xli (A) with MMC ecu..for sure no OBD port... been changing the MAF sensor and still intermittenly popped out.....
would check tps sensor next and probably the distributor as well.....
and perhaps flushing my ATF since 1.6/1.8 proton auto got TCU (transmission control unit as well) :hmmmm:
p/s: mine was stock engine with stock airbox (modded with CAI funnel)..replaced petrol filter and air filter as well
arsengal
18
503
Damn, the thing happened again, twice just in the space of 5 hours. Really need to go to the workshop and get this thing settled once and for all. The car seems very underpower when the thing happens. And the jerking when the RPM hits 2K is just damn annoying. :bawling::mad:
15,390
Wiras (especially the 1.3 and 1.5 variants) are very old. 1.6 also. All have crank, MAF/MAP, O2 sensors and these aren't permanant, they will fail with time. Worthwhile replacing these sensors one go after about 8 to 10 years.
Throttlebodies in the VDO are very sensitive too. The TPS and the mechanism inside is very sensitive so if you ever dismantle the TB for cleaning make sure you don't suddenly jerk it or drop it or knock it. Any sort of movement much jolt it out of position and you'll need the PDT diagnosis machine to reset it.
MMC TBs are less sensitive but also wear and tear. I can't remember what its called but it has a TPS or something inside as well which is made of plastic.
But usually loss of power indicates a sensor problem. Check sockets, sensors, the wires, and in my case - the coil was dying so it was intermittent.
The beautiful thing about the Wira is if you choose to change all of these things one go, it's still not going to be overly expensive to do it. On a Campro or something newer, prepare to sell butt to pay for the fixes.
I juz install a 6000k hid.But i feel the beam not so sharp.Can i know how to adjust to a good position the beam.Adjust high low also
