I would set aside RM10k for a proper job with almost no recon / halfcut parts. I don't trust those type of parts unless it's a aircon compressor or something unimportant. halfcut pistons, turbos or cranks - that's scary unless you know how to look out for the lemons.
I'll suggest u go for a full engine transplant if u wish to turbo your myvi. Reliability and cost wise, bot will always falls behind a full engine transplant. A bot will set u back at least 10k doesn't matter whether u are go for low boost or high assuming u are getting all parts new. Higher boost will cost u more. For full engine transplant will cost u roughly about 9k, k3-vet halfcut- around 6k, labor and workmanship about 1.5k, overhaul with internal tear n wear replacement- around 1.5k but in return u get a peace of mind while boosting on the road. Reliability is the key here plus cheaper to maintain in long term and cheaper overall package of course.
In short reliability for bot will not be much of an issue if u get all the parts right with proper tuning and maintainence. Do bear in mind though a na engine is always at it's best when used as it is thus by bot even with all the tuning and parts replacement, in the end U'll still be shortening the lifespan of the engine as well as accelerating the tear and wear. That is the fact.
Seeing this makes me sad la... Are used parts really that bad? I am thinking of using everything new except for crankshaft and conrods. Because I heard my 4AFE can fit in 4AGZE crankshaft and rods easily. Pistons will get new of course. Im just aiming for low boost also like our bro here, so actually no need to change crankshaft. But I was thinking if I overhaul my engine, might as well put in a tough part there just for safety.
So what do you guys think? Original crankshaft (not meant for boost) more reliable or a used supercharged crankshaft (means for boost) is more reliable???
Depends. A BOT can be put together for the same price as an engine swap and be just as reliable if done correctly. The only tricky part is engine management. If you do it right the end result will be just as reliable as engine swap, and more powerful. The same cannot be said for the N/A's transmission be it manual or automatic. LOL.
That's not a fact, that's false. The answer is it depends on the engine design. Since the guy was asking about the Daihatsu/Perodua engines, the K3-VE block is exactly the same as the K3-VET block. The conrods are exactly the same, the heads are interchangeable, the only difference on the engine is the injectors and low compression pistons.
I was replying to the TS's enquiry, not into a particular engine, rather generally on bot topic. Most bot are done on na engine or else it will not be called bot. Anyway if u wish to highlight it in a particular way by all means. Na engine with proper maintainence can last for at least 20 years, some 30 years. But I can't say the same for bot engine though. Thus my point there. Personally i have yet to see any bot car which lasted more than 10 years. Perhaps i have yet to see it. To each their own.
Don't generalize and say BOT won't last. That's spreading unnecessary fear and misconception.
NA engines BOT that have a turbo sibling engine based on the same engine block will definitely last as long as a factory turbocharged engine, if not longer, when done right. As the factory has already done all necessary R&D on the engine itself.
A Campro BOT for example. I have no idea. Whether that block can withstand turbo or not is anybody's guess. The Campro CFE is essentially a new design and different from usual Campros according to Proton.
bro alvin, imo if you're buying a 60k accord and then spend some 10k to slap a turbo i think better you gather those 70k and buy preve,ori turbo tau... and brand new summore...low interest for sure... or get an airtrek turbo.. so many model to chose...toyota estima also got supercharge
what i'm trying to say is,if this is your 1st time modding a car or 1st time using turbo...please consider it in stock form.if you wanna gain knowlegde from a 10k wira i can understand,but a 60k car can make ur head spin
Haha... Personally, I would buy a 60k jap car and turbo it instead of buying 70k new proton. Just light boost it.
All will boil down to your financial stability. If u got a strong background financially or got a strong financial support behind, by all means go for a used jap car and bot it. Otherwise go for a new car. Be reminded taking care of the tear n wear of a Honda is already quite tedious and rather costly not to mention taking care of bot car. I owned a Honda FYI plus a bot owner as well and I'm telling u bot is more costly than u think. Go n ask other owners. FYI again most of the bot owners here are either tuners themselves or mechanics or financially stable guys including me thus for them it is nothing for everything can be diy besides earning some as well from the likes like us. Think and plan carefully before u step into the world of bot. It addictive but also an expensive hobby to keep. Make sure u have at least 15-20k of spare cash before u embark into the world of bot. I can assure u a mere 10k will not be enough for bot alone plus u need to leave some spare for emergencies such as gb or engine kaput or a total overhaul. Just my piece of cake. Your call.
Check pinned bot forum, posted inside already, all items brand new. That is not it yet, still got a couple of items yet to be accounted for. A friendly advice, if u want to play bot, do it all the way. Why take the risk of going for used items where reliability will be an even obvious issue? Unless u are a mec or got your own workshop then it is another story. But that's just me. Currently still dealing with a couple of wear and tear issue from the suspension system of which I strongly believe arise due to the na parts unable to cope with the sudden steep increase of torque n Hp.
Jus a 30k Accord CG. Murah beb...
with 10k-15k budget.
i rather plonk in a k20a engine than bot.
seriously.!
if you want to play turbo.
get other car.
not a honda dude.
Originally posted by oilman
No they are no good.
Have a read.
General Remarks on Chlorinated Additives.
A number of ‘add-on’...
