ceffy_999.. i faced the same problem on my sir-t and also on my cl1.. 1st adjust the clutch pedal higher..then try.. if cannot try mtf3 honda gbox oil.. solved my problem.. still cannot it means taking the gbox apart.
alwhitesat said:problem solved immediately after using the oil, no sound, no crunching, u will shift smoothly afterwards...i've been using the oil almost 4 years now, also in sepang track, no issues at all!!.
I used to have same prob with my sir-t.. Replaced gearbox oil with 20w 50 engine oil, same as alwi.. 2 years already, no more gear synchro issue..
Yesterday just change the gearbox oil & check the clutch pump already (no problem). Still facing the same problem. Plan to remove the gearbox next month to check & change the clutch & clutch cover as well.
1. Just wondering if it's syncro problem, how much would it be to buy a brand new syncro replacement? The syncro is only for 4th to 5th gear?
2. Can the syncro be repair? As some foreman said it might can be repair.
what oil did you use?? i asked about the the syncro was around 600 plus..
Hi Guys,Im Kinda New Here.Just Want To Ask About Accord CF4.Is The Car Reliable?Im Thinking Of Taking The Shiftronic Gear Instead Of Manual.Easier For Me.So Any Suggestion,Comments Or Anything Good/Bad About The CF4?Thank You... :)
go get a bottle of honda mtf3.. 4 litres rm180 in purple metal can made in japan.. try that if still cannot then take apart gbox.. it helped me in my sir-t and also my cl1 and also my friends cl7r.. i used motul ff lsd, redline as well before... shift into 5th gear at high speed crunch.. started when i cucuk a nissan 350z twin turbo and a gtr all the way from ipoh to kl.. then when i was using cl1 had
the same problem, again changed to mtf 3 and shifting like butter.. just my experience.. hope it works for you..
Where to get the honda MTF3 gear oil? Any spare parts shop got sell it?
haloooooo evelyone........hehehehehehe......long time not seeeee......
bien... long time no see...
me busy with family la since the third one came in 3 weeks ago. car wise... i'm a honda owner again after a 2.5-year hiatus. i bought a honda minivan. the one with sliding doors... truly a van bawak barang :)
mini van la... elysion is a mega van la... 1.5 saja
. So now I need to replace it. How much for the new antenna? Or any better aftermarket? Thanks.
