B16A Engine Modification Advice Needed !
AD_EG
6,328
231
Ipoh
hahhaha but he's right la...b20 really worth the money..just pandai2 jaga oil,water and revs.. very nice n fun to drive..
ddv_nk12
1,228
236
PD
Second that!!
mADmAN
1,840
547
sapa mau??? mau kalu....kasi inform....
then i can give details about the block...coz its not exactly stock...hence i said "semi-built"
ddv_nk12
1,228
236
PD
got trial ah madman? tak best money back guarantee. hahaha
Haha. Good one.. I think madman will let you use first, if you're satisfied then only pay.
mADmAN
1,840
547
Mana ada...pay then only angkat...this is engine block ler....not some small component. :p
ddv_nk12
1,228
236
PD
Haha. Just joking. Try posting it for sale in marketplace or mudah la. Maybe can cover cost for your next upgrade.
mADmAN
1,840
547
wanna post...but lazy take pic hahahhahaah
ddv_nk12
1,228
236
PD
Block all the same only. Just google it and post. Most important thing are the specs. Hehe. Good luck!!
tsmlawz
50
1,508
Damansara/PJ
Dont waste time and money modding b16a auto,I used to drive a b16a auto mod with b16a manual cam+fgk sflow+fgk 421+2.3inch pipe and vafc...the performance still cant compare to a b16a manual. If u wanna keep auto then just find b18c or b20b block but dunno ur gearbox can tahan or not la.
1 questions seniors!
Why is it B16A auto cant compare with B16A manual?
DeaconFrost
284
159
Well bro, one of the things that made the B16A competitive is the manual gearbox that comes with it.
Rev-wise, the auto do not even allow you to rev over 7700rpm, and you can see this on your meter.
High redline allows B16A to brake later going into a corner, and downshift harder, but a 7700rpm redline is going to be a b*tch. B16A is a short stroke engine and all high-revving Ferraris, Lexus LFAs have short stroke, so limiting it to 7700rpm is throwing away it's advantage.
Last time I own an EG6 and I can have fun, now I have an auto EG9 for my daily ride and when I want to downshift I can only see D3, D2 ahahahahaha...
Lose the auto gearbox and you'll be a happy man.
shah5755
355
31
Pj....kch
last time i did read sumwhere the auto cam and manual cam slightly different...manual cams more wilder the cam profile....correct me if i'm wrong sifu:smokin:
mADmAN
1,840
547
correct...the cams on a manual and auto B16A are different... if not mistaken even the compression ratio on the auto is slightly lower..
tsmlawz
50
1,508
Damansara/PJ
OOh i see, if like dat meaning stock B16A auto engine itself also less stim compare to B16A manual engine d.
What bout changing cams and piston will it par?
hehe.
planning to take it easy =)
mADmAN
1,840
547
hehe.
if ur gonna change pistons, better to get B16B (PCT) pistons...higher compression... and theyre not that expensive and easily available, especially if ur looking for brand new
cams...yeah manual cams will be better..but again...type r cams are even better hahahahha
if changing b16a auto to manual worth it? cost wise?
or straight away change whole halfcut to b16b/b18c
2-3-4k iirc...cant remember the cost...but also depends on the parts u get. yes worth it :D
ddv_nk12
1,228
236
PD
**wrong info**
mADmAN
1,840
547
2-3-4k is for the manual gearbox only? or for the full conversion of b16ab/b18cr?
converting ur manual to auto...basically the gearbox, clutch, clutch pumps, pedals, and watever needed for auto-manual conversion
engine no touch.
ARTA NSX wins revenge race
The JAPAN GT CHAMPIONSHIP MALAYSIA, Round 4 of the 2006 AUTOBACS SUPER GT series was held on June 25 at the Sepang International Circuit.
Images by: Andy Goh
Despite the thin cloud cover, the temperature...
