the air will end up at air filter. thats where the sound produced. thats why i said listen carefully between BOV and airfilter.
If BOV can't hold pressure be it spring rate too low or the Teflon inside already worn off this is quite common beside that you boost on 1.4bar high boost.
must use greddy adapter/flange..cannot use ssqv ones.
thx for the info bro..
btw any1 been using hks sqv imitations? how's the quality? it seems non adjustable, wont causes turbo surge?
I was using ori japan ssqv 1 before, but no sound,
after using ssqv2 taiwan it works now....
mine is from taiwan...as long as yr boost below 1bar u should be fine...
if more than 1 bar use greddy
enkei_rs said:Now using Blitz ss series on my 6A13TT with 0.6 Bar maximum.
But sound not so loud and normal "kepish" sound.
Any advise with nice sound and work with 0.6 Bar.
Admire the bird chipping sound.
It you don't mind the sound maybe you can try to use Tail BOV I think it don't have imitation yet. For HKS & Greddy immiation is close 99% only can tell by the logo itself. Ori brand logo are very sharp but immitation is fade abit but still very hard to tell if you don't have ori to compare.
