hi etech, just for update. I had replaced my p08 and iacv for peace of mind....![]()
thank you. the 28 pin external chip is not open. but j1 is open to run internal chip.If the EPROM is original from factory then you shoudn't leave it empty. You either remain it or repalace it with another upgraded chip. If leave it empty sure will have problem.
tnx etech i try to replace hc373Hc373 or while removing the factory chip you
hv damage the copper trace.
nice thread E-Tech.. i just bought p08 ecu (auto). planned to rechip it myself for my stock b16a manual since im a low budget person n motivated by this thread..hihi so where can i get all parts needed (chip, socket, etc)? can i order from u? thanks.
hi etech been long time since i log in.
i got this p08 running on a nonvtec engine for some time..
one time i started it, it wont start. throw TPS and MAP. I reset and it go way but still car wont start
replace with original ecu p27. works fine now..
tested the p08 on d15b vtec stock. car wont start no cell
any idea? injectors ic may be or something..
Hi etech,
yes fuel pump is working.. try to replace IC12..
---------- Post added at 06:06 PM ---------- 6 hour anti-bump limit - Previous post was at 04:01 PM ----------
hi Etech
i just replaced IC12..
throwing tps ang map CEL..
any idea why..
should I replace QM3 and QM2
enigne sounds like misfiring.. idle plays around 500 -700
---------- Post added at 06:08 PM ---------- 6 hour anti-bump limit - Previous post was at 06:06 PM ----------
hi Etech
any idea why..
Hi...
Confirm injector by injector... Check if all working...
But I guess it is still related tps and map related circuit...
Any burn mark?
