anyone have rechipped a stock ecu with external chip already. i am sure its stock since solder was very clean and the same with other components. p08-900 auto
question: i remove the chip and place the chip bed then put the chip back.
remove rp17 and jumper rp18
tested and all is ok..
now i place a switch so it can run stock and chip.
tested switch to chip, everything is ok no CEL
tested switch to stock, CEL 19 WTF!
please need inputs thanks
Key off then key on again. Still got cel19?
First time after switch will occur Cel, but after key on and key off, it should run normal...
