the GSR piston is from what model LANCER E-CD5A or E-CM5A(enjin terbalik)?cozz 4g93t CM5A(terbalik)the compression ratio is 9 but the 4g93t CD5A comperssion ratio is 8.5
cannot, cos evo pistons are too big,
std 6a12tt pistons are 78.4mm, can only rebore max 2mm.
4g93t piston is 81mm. so should be safe.
but it must rebore bout 2.6mm right...78.4-81=2.6mm max is 2mm it is safe...?:hmmmm:
code 222, 232 from eterna 1.8 & 2.0 is 8.5"
if 312/332 eterna v6 n/a & TT is 9".
if u using 8.5" now but wanna use 9" flywheel i think kenot la bro....
the gbox housing kenot fit.
using sei engine with manual tranny isit?
sei can use evo3 manual gbox set.
for v6 can use
1.222
2.232
3.312
4.412.
