Wastegate Explained.
speed2horizon
2,798
334
1,683
speed2horizon, would like to ask u a silly question
what are the differences can be found between turbosmart and tial wastegate
much appreciated
ehemm ehmm... Tial wastegate piston and shaft are separate piece and can be dismentled. They are in 2 pieces. In long run there are possibility that the fitting might get worned out by the pressure, temperature and continuous movement during turbo spools. But this might happen after years...
the turbosmart piston n shaft is a one piece. No chances of getting lose, which is what I prefer. They also claimed that they flow better due to the bigger exhaust buffer volume and the effect is less chances of spiking.
However, both are great wastegate to be used.
That's all I know. Sorry for the limited knowledge.
rakesh_v6
919
22
tats okay,u had explained well...at the moment am using tial but am kinda keen for turbosmart.i have been reading forums bout it and found out not many differences between both of them...kinda confused shall i change it or no :idea:
chrissyong
975
14
much appreciated
the turbosmart waste gate and tial wastegate difference not much at low boost,if u boost 1bar u can feel the tail wastegate spike till 1.1 bar,that one i can sure,if turbosmart wastegate wont got that shit thing,if u use vp racing or methanol or hi boost your tial wastegate 100% will harm!!!
speed2horizon
2,798
334
1,683
I am even more confused now... Why would U change something that is already serving U well. Only change it if Ur Tial spoil.
This is one of the fatest racing machine in SDB. Clocked <10secs. It also uses Tial...
What's wrong with it that U need to change it when it's working fine..?
contreasjun27
9,000 RPM
9,045
25
subang
haha Rich mah thats why can change like that keke...
maybe color is the problem...thats why need to change color keke
rakesh_v6
919
22
naa i was told by someone that tial aint reliable and it does spike...after ur explanation i have some clear picture..thanks for the info speed..much appreciated
KRZ8v
Beyond 20,000 RPM!
20,987
4
KL/Subang Jaya
Well, it works the same way like ur internal wastegate. At low boost, the wastegate releases more exhaust gasses, at high boost, the exhaust gas is used to turn the turbine remaining less exhaust to exit through the wastegate.
However, due to the price difference of 38mm and 44/45mm wastegate, most of the ppl will get a 38mm. They'll work fine.
The best place to mount ur wastegate is where the stock internal flap is. Get the flap removed buy a customize flange with 2 holes. 1 hole foe turbine exducer and 1 hole for wastegate. Extend the hole for wastegat. With a 1 1/2" schedule 10 pipe and mount ur wastegate there. Remember to port the hole on the turbine housing to 38mm to suit ur wastegate. If u doesn't like the noise of the wastegate, u may vent to wastegate outlet back into the downpipe.
An alternative location would be removing the flap on ur manifold outlet and mount the wastegate at the centre of the hole with the wastegate inlet pipe on top of the manifold. Please make sure the fabricator knock off all the welding flux and left overs COMPLETELY. If not handle propey, it may comes out later and damage ur turbine fin later.
I have mine mounted between runner 1 n 2. But I bored a 38mm hole, shape the manifod flat at the place where I mount my wastegate, then weld the wastegate flange on the flat surface. My welding is only at the top of the manifold.
Hope it helps.
Thanks bro....:adore:
chrissyong
975
14
if u got boost over 2bar exp with tial wastegate and turbosmart then u will know about that,the faster is not wastegate problem is turbo and engine tune setup problem,the user have been try turbosmart and tial wastegate before will understand my word~the low boost user or newbie user very hard to know that,we will prove it at sepang drag this years
---------- Post added at 01:55 AM ---------- 6 hour anti-bump limit - Previous post was at 01:50 AM ----------
cause my self also is turbosmart user,wont trust me can go turbo smart forum see the turbosmart waste is vp racing race gas or full methanol family or not,but i did't not see tial wastegate website have explain anything...
jinkl
4,624
376
3,183
chill guys, dont fight
the only problem with tial is , tial in malaysia are mostly not original
im also running turbosmart , speed2horizon is also running one
i faced problems with the turbosmart bt was solved with help of sdf with lil tweak of spring rates
one more issue in malaysia is choose the wrong size of wastegate n etc
tials are proven same as turbosmart :) we are still far slower than the other cars in US who is running on tials, they run higher boost than nearly all sepang cars
john shepherd 7sec 4g63
http://sphotos.ak.fbcdn.net/photos-ak-sf2p/v288/197/78/19738257875/n19738257875_731187_7600.jpg
evil eagle 8sec 4g6x
http://www.dsmtuners.com/gallery/files/1/0/2/1/2/2007build032_1.jpg
twicks 9sec 4g9x
http://www.dsmtuners.com/gallery/files/2/8/7/2/3/4.jpg
so dont worry guys, its ur choice , i head for turbosmart becos i want to avoid the fake tials
KRZ8v
Beyond 20,000 RPM!
20,987
4
KL/Subang Jaya
Just for your information, get a bigger midbox and exhaust system before the heat and back pressure damage ur O2 sensors and turbine. 2.5" for a 1.6 will be good...
Oh, my o2 sensor is not plug in btw. Its juz mounted there to plug the hole:biggrin: 2.5"??? Hmmmm.... not too big meh???:hmmmm:
chrissyong
975
14
twicks 9sec 4g9x
the picture picture look like hehe,but anyway u got the point already..
renxun
1,138
37
1,648
me too bro..just to avoid the fake tial in the market.I really unable to differantiate the fake and the ori tial.
price wise more a less the same.. so just try out turbosmart and it serves well
speed2horizon
2,798
334
1,683
twicks 9sec 4g9x
U came in at the right time babe.... I was just looking for the pictures... I thought the STWANGAN's 9 secs 4G63T is impressive enough.. But it isn't...
OUT OF TOPIC A LITTLE, Bro.... I changed my Satria's leg from Japanese T to Local T already... Felt SUPERB.... Haven't been having this kinda feeling for a long time...
Wow.... Unplugging the O2 sensor will make ur car runs Open Loop all the time. No AFR feeback to the ECU. It'll increase the fuel consumption of your engine.
In turbocharged engine, we have before tubine and after turbine exhaust. So, big exhaust is not a problem. 2.5" is just nice for a spirited driving 1.6 supercharged engine... If you wanna prepare for higher boost application, U may opt for 2.8".. But too bad, this size is very RARE in Malaysia....
Not the story anymore... Turbosmart price went up by RM500 for the 45mm within the past few months... Kekeke....
I opted for the TS because of the
color and shape
finishing
smaller community
single piece valve(2nd most important factor)
immitation of TiAL(The most important factor)
Cheers..
KRZ8v
Beyond 20,000 RPM!
20,987
4
KL/Subang Jaya
@speed2horizon
Yup.... dats y most of the time weekends only I'll drive the car.... The car is not environmental friendly and economical... 1 2 overtake oso exhaust smoke like Pajero diesel hahahahahaa..... Maybe I'll opt for 2.5" piping when my old rusted piping start to give way...
Thanks alot for the info btw... cheers
The Marketplace Top Posts
Dear Sifus,
I heard that my '08 1300cc engine has the exact same layout as the 1600cc engine found in the Gen.2!
So is it possible that I just switch my 1300cc head with the 1600cc and make mine an immediate upgrade?
I know its too naive but please enlighten me.
