ECU repair? How much?
levin818
1,260
321
3,183
Shah Alam
can post to you levin818?
Yes you can do so. Please check your PM for my mailing address.
---------- Post added at 01:49 PM ---------- 6 hour anti-bump limit - Previous post was at 01:00 PM ----------
... experiencing pinging when i open the throttle wide at low RPM like when driving up steep roads.
... on idle, i'm getting the lovely mist around the muffler...
Hi FGT, pinging could be due to too advance in timing, fuel system problem or even due to a faulty ECU. Suggest you look into above areas.
Mist around the muffler? This is serious man. When was your last visit to the workshop? Better bring it to your mech asap. Certain things we can't DIY ourselves and has to leave it to the mech.
FGT
529
31
LOL sorry. I meant i'm getting wap air coming out when it's on idle. Not mist per se. I thought the ignition timing is spot-on if that happens?
Timing was set to stock as per manual last time I service. I'll take a look at the fuel system then. If it persists, ECU -- will come to you. Thanks bro.
levin818
1,260
321
3,183
Shah Alam
No problem man. Buzz me if you would like me to see look your ECU :biggrin:
bera
822
229
huh...scary looking pic there...
may i ask you to look at mine too...??i pm you the details... :biggrin:
dinster
12
Bro Levin818,
I just SMS U. Need your service to rebuild my AE101 93' Auto ECU ..
Dec 4, 2014
kedah kulim
Hi levin818, will advice regards my car ford laser lynx 1.6 (a) 1995, which has burn few component only and the thrace still good.
Is can be repair? How much the cost might be?
levin818
1,260
321
3,183
Shah Alam
Hi vith, for '95 Ford Lynx/Mazda Lantis ECU, if the burn is still in early stage, possibility to recover the ECU is 100%.
If the situation has drag for too long, until 12V already crossing into 5V rail... its beyond repair.
Can you please snap some photo and WhatsApp to me at 012-2988 960? Tks
shamburke
2,244
12
Subang Jaya
master sifu levin818,
hi long time no see..... can look at my W209 SAM unit???
DanzEterna
15,911
3,371
www.primeperdanaclub.com
saved your number too incase require your services in the future.:smokin:
KeMa
76
16
5,008
Selangor
www.ithink2invest.com
levin818
Interesting works done!
I'm using 4AGE 20v Blacktop and confirm my ECU problem because there is a burning at few of it IC. Then i change to a 2nd hand ECU. But unfortunately, the idling rpm is erratic and the car jerks badly exceeding 3k rpm after a week i used it. My mechanic told me that there is a 3 month warranty for the ECU but it has been 2 weeks i still haven't got any replacement.
where is your location? i think i want to bring my ECU to you for rebuilding it..i think that would be better than having anoter 2nd hand ECU which i am not sure the condition of
i'm planning to install a set HWL adjustable to my wira 1.3....but the problem is here
izzit the HWL adjustable for Wira are same model with Waja,Satria,putra?
means even wira 1.3 ,1.5, 1.8....also use the same model?
like HWL adjustable current using on Waja 1.6....but it also can fit to Wira 1.3??
thank you
