can someone provide me roughly cost for this type engine conversion??
saga blm 1.6 crankshaft = RM???
saga blm 1.6 conrod = RM???
bolt on turbo kits = RM3.5k
anymore??
prepare abt rm2000-2300 if u want to change to 1.6 stroker.
u can retain the 1.3 piston and u will have a high comp 1.6.
if u want to turbo the use 1.6 piston or cfe piston(not sure can fit or not)
u will get better torque,hp is not increase by much.
yours is auto so u wont feel the gain as much as on a manual.
turbo will require change of piston to reduce the compression.
u can bolt a turbo kit alone but on stock ecu and injector,not much gain for the money spent.
again,yours is auto so dont expect much.google and find how much power is loss
in an autobox.
i would suggest just go for easy bolt on part and not turbo.
this way u will retain the running cost and durability of the motor.
plus,its easy to reverse the mod and sell the part seperately if u want to sell the car.
use the money to mod your new car in the future.
bolt on part like:
-extractor and exhaust system
-air filter
-crank pulley
-better suspension
-better brake
-good tire
-some strut bar(front 2 point,front lower arm,rear anti roll bar)
total for the part above can go beyond the cost of a turbo kit but remember than once u install
the turbo kit u will need to upgrade your brake,suspension,cooling,chassis,tire as well.
so u will end up spending more.
goin fast is not a simple matter of squeezing hp out of the engine.
the surrounding parameter such as braking,cooking,handling must also be talen inco
on engine transplant,not sure if the 1.6 cps engine is a direct swap to the blm.
get the manual gb.
