Difference between L2 and L5?
YellowFlash
308
34
Jb
hi dear sifus that owns and drive a kancil here.... can you explain wats the difference between L2 and L5? the engine capacity, hp etc? thx!
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Got this from another forum
this is the different between L2,L2s,L5
L200(EF-CL) - 659cc 6v sohc 40ps/6.5Krpm 5.3kg-m/3.5Krpm NA
L210s,210v(EF-HL) - 659cc 12v sohc 50ps/7.5Krpm 5.3kg-m/4.5Krpm 4WD turbo
L200(EF-XL) - 659cc 6v sohc 61ps/7Krpm 8.6kg-m/4.5Krpm turbo (carb)
L200(EF-KL) - 659cc 6v sohc 42ps/6Krpm 5.4kg-m/4Krpm NA
L200(EF-FL) - 659cc 6v sohc 40ps/6.3Krpm 5.3kg-m/3.5Krpm NA
L200,200s(EF-JL) - 659cc 12v sohc 64ps/7.5Krpm 9.4kg-m/4Krpm turbo
L500s(EF-CL) - 659cc 6v sohc 40ps/6.5Krpm 5.3kg-m/3.5Krpm NA
L500s(EF-KL) - 659cc 6v sohc 42ps/6Krpm 5.4kg-m/4Krpm NA
L500s(EF-FL) - 659cc 6v sohc 40ps/6.3Krpm 5.3kg-m/3.5Krpm NA
L500s(EF-JL) - 659cc 12v sohc 64ps/7.5Krpm 9.4kg-m/4Krpm turbo
L500s(EF-GL) - 659cc 12v dohc 52ps/7.2Krpm 5.8kg-m/4Krpm NA
L510s/510v(EF-ZL) - 659cc 12v dohc 55ps/7.5Krpm 6.2kg-m/4Krpm 4WD NA
L500s(EF-RL) - 659cc 12v dohc 64ps/6.8Krpm 10.7kg-m/4Krpm turbo
L502s(JB-EL) - 659cc 16v dohc 58ps/7.6Krpm 5.8kg-m/5.6Krpm turbo
L502s(JB-JL) - 659cc 16v dohc 64ps/7.5Krpm 10.2kg-m/4Krpm turbo
L512s(JB-JL) - 659cc 16v dohc 64ps/7.5Krpm 10.2kg-m/4Krpm 4WD turbo
Note:
6v denote 2valve per cylinder for 3cylinder configuration and normally single cam (SOHC)
12v denote 4valve per cylinder for 3cylinder configuration and normally twin cam (DOHC)
16v denote 4valve per cylinder for 3cylinder configuration and normally twin cam (DOHC)
YellowFlash
308
34
Jb
thanks bro and btw do u mean tat 16V means 4valve per cylinder for 4 cylinder engines? according to the information...seems that the L5s with 16v are the most powerful of all...so are most of the kancil here fitted with L5s engine?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
for certain L5, it uses 4 cylinder engine... you can identify it from the list based on its code... it starts with JB, JB-EL for NA and JB-JL for turbo... Daihatsu Move L6 also uses dis engine...
FYI, for Move L9 series it uses JB-DET with a redesigned head... some says more efficient but still the same block as L5/L6 JB series
YellowFlash
308
34
Jb
icic...thanks for the info...btw i think i edited my post while u were replying so u miss out some questions i asked....i was asking whether there are more L2s or L5s converted on the road? which is better??
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Nowadays, L5 users are catching up fast due to parts getting easier to get these days.... now its a matter of preference...
L2 Pros and Cons
  1. Pro - Parts exchangeability wif kancil and some kelisa
  2. Pro - Since L2 arrived earlier, most performance tuners already understands L2 design and limitation more
  3. Pro - Easy upgrade from 660cc to 850cc/1000cc simply by changing block from kancil/kelisa/kenari
  4. Pro - Less headache when swapping since its a direct bolt on
  5. Cons - its an ageing design. It last stop production 1993
  6. Cons - Prone to overheat on long distance hi speed cruising
  7. Cons - Suffers same air con issues as kancil even after swapping with L5 dashboard and blowers
L5 Pros and Cons
  1. Pro - for the 16v models, its smoother than L2
  2. Pro - Capable highway cruiser... so far no overheat
  3. Pro - It uses timing chain, so no more timing belt issues
  4. Pro - The aircon are colder and more reliable
  5. Pro - Newer design than L2, so more likely to see untouched (i.e. not overhauled yet) unit at hafkat
  6. Cons - Parts are not easy to come by, but they are increasing in numbers..
  7. Cons - Tuning capabilities are still limited since tuners still learning its design and systems
  8. Cons - Not so easy to swap if you don't have the original subframe...
I hope that L2 users correct me if I'm wrong...
IMHO, L2 are best for performance junkies... L5 for ppl who want to take it easy... but stock vs stock both are the same....
but then, at drag strips, autocross in japan all uses L5 engines right so its a matter of time L5 will replace L2 as a performance option
for me.... I'm a recent convert to L5 16v turbo :biggrin:
...and loving it :proud:
YellowFlash
308
34
Jb
thx for the very comprehensive summary of pros and cons for L2 and L5, anyway congrats on your L5 conversion. Previously were you using L2 convert? btw how much does the half cut for L2 and L5 cost? :)
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
before dis using 850cc inj from factory :biggrin:
last time i check for turbocharged models in klang valley inclusive installation
  1. L2s manual RM3300
  2. L2s auto RM3100
  3. L5 16v manual RM3800
  4. L5 16v auto RM3800
but budget for 5k in case something went wrong... normal la hafkat, we dun know for certain the condition rite? one thing for sure if you wanna go manual, change the clutch plate + cover first since kancil are notorious when changing clutch i.e. have to take out the engine to take out the gearbox
you can contact dis 2 guys if you are in the klang valley
apeng @
syah @
no need to mention me (prolly won't recognize my nickname)... dis guys are ok even if you just called to ask for price...and easy to nego oso :biggrin:
YellowFlash
308
34
Jb
oh thx for add info but klang sounds far for me, haha ...i am located in jb. Anyway i am aware that kancil comes in many different models, how do we actually classify them and what are their specs for eg: the 660cc and 850cc in terms of their hp and stock 0-100 timing(or maybe stock engine cant really hit 100?). Also how much does a kancil modified/unmodified cost?
I apologise for the huge influx of questions but i think it'd be easier if i ask most of my questions in a single post, so it'd be easier for you to reply... :D
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Refer here KANCIL SPECIFICATION
but that for the older kancil... my 2003 kancil originally came wif ED-DE engine which is 850cc Twin Cam and using fuel injection... power rated at 50hp...same as kelisa's 850cc version but with 3speed auto gearbox...
as per 0-100 timing not sure... but surely stock engine can go 100kmh... just need a long... long road for the 660cc models :biggrin:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
oh i mean the cost for buying a kancil 660cc and 850cc stock and modified....
haha... i think you should search the "Cars for Sale" threads
mag9556
2,770
43
1,648
Sifu giving advice man!!:adore::adore:ha3..
Actually the most powerful stock mira are L500s(EF-RL) - 659cc 12v dohc 64ps/6.8Krpm 10.7kg-m/4Krpm turbo (look carefully.. its 12v onli.. 3 piston..he3)
YellowFlash
308
34
Jb
haha, but also notice the lower rpm ranges due to having 1 lesser cylinder...anyway im glad the sifu here is very helpful :biggrin:
mag9556
2,770
43
1,648
if u are using 850 twin cam kancil engine.. u can just rojak it inside.. to power out will be beyond ur expectation...
me using this engine for 4 years already... stock auto power are much more better than manual l2s turbo...spare parts.. tons of it...he3 look on the torque not the bhp and cc anymore..
u will knoe once u have it..
forgotten.. redline same.. 8krpm
YellowFlash
308
34
Jb
yea i noticed the torque is stronger...but i heard 4 cylinders run smoother than 3?...is that true?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
manader de sifu.... read from buks and wiki la...and learn from you la
EF-RL maybe the most powerful... but still I like JB-JL... smooth! :driver:
mag9556
2,770
43
1,648
Indeed 4 piston is smooth.. this 3 piston engine is not as what u see at Kelisa.. the engine smooth like 4 piston... just like got balancer inside.. never open it before.. will try to open it one day..he3
mileage clock 200k liao....
Anyway.. depends on u actually to use 4 or 3 piston.. somemore.. for 3 piston, normal kancil bonnet need to jack up if without airscope... too hot...
ha3 where got.. me riding ori le.. u riding G-Force monster d...:driver::thefinger:
Me will be changing to 4 piston one la one day.. old liao... not just want to use Auto but chain belt.. less maintainance...
YellowFlash
308
34
Jb
haha...im glad to see 2 sifu posting here and i really did manage to learn quite a bit of stuff. Anyway for kancil, how many different models were there? i noticed some are manufactured in late 90's and some are much newer like that of yours papagoines and this year it stopped production with viva replacing it.
mag9556
2,770
43
1,648
1st batch - like l2 bumper onli 660
2nd batch - belalang bumper thats where the 850 appear
3rd batch - vr4 grill 99' batch
4th batch - the latest one.. totally different head somemore 850auto come out in twincam.
thats all i knoe.. btw.. me kutu kecik onli.. compare to sifu papagoines:adore:.. sky and land (basement not land ha4)
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
nope my engine still produced late 90s.... latest ones are the KF series found in Mira Avy or Viva as we know it...
Perodua VIVA still uses old engines like
660cc = EF-VE (EF block like L2/L5 3cyl but with VE head i.e. equipped wif DVVT mechanism)
850cc = ED-VE (ED block like my old engine but with VE head i.e. equipped wif DVVT mechanism)
1000cc = EJ-VE (EJ block like kelisa 1000cc but with VE head i.e. equipped wif DVVT mechanism)
aiya mag.... pulling my leg... he's the bigger sifu than me
p/s: blalang style came in early 2003 maaa
YellowFlash
308
34
Jb
thats cool...seems like alot of the engine parts of the kancil are interchangeable just like a old honda engines where they can use the different heads for different blocks... anyway i do not understand malay, could you all enlightenment me wat is "belalang bumper" and "kutu kecik"...
haha thx sifus! :biggrin:
