EK Bushing
Areignz
281
Harder suspension will shorten ur bushing lifetime.I recommend using OEM for better daily rides.Use Japan OEM parts.Can save ur budget and time.If u rembat kaki then u uses the teflon or pu bushes la.Macam naik kete kebal daa rasa dia.
Hikaru
3,665
22
Atlanta, GA
photobucket.com
exactly my point, I highly recommend OEM Japan parts. The day I swapped everything out, I was a happy man driving the car away from workshop with the feel of driving new virgin car.
nehemiah
109
Hmm... my car is squeaking badly. You guys who change your bushings, does it help stop the squeakyness? Sport springs and coilovers make squeaky sound also ka?
rapinsoul
232
4
I have another question now, lets say that i have replaced all my bushing, later on when i swap a CTR cut into my engine back and i also change the crossmember can i take out the bushing and use back?
rapinsoul
232
4
Damn thats bad... again after that need to redo the bushing :banghead:
BlackHD
374
i did mine in puchong, complete entire car except the 3 big engine bush... for about rm800... all original honda bushes, the mech knows i always demand for original parts regardless the price. location puchong perdana/intan
Hikaru
3,665
22
Atlanta, GA
photobucket.com
if only for the bushes, then it sond expensive, if you did include the upper arms for front and rear, then it sounds too cheap.
Honda does not sell the front trailing arms bushes separately so you have to buy the whole front trailing arms for rm450~550 each, that will sum up rm1000 real quick for all front. Unless you have lobang to get them loose by pumping out the old and replace with new.
Then you need to buy
Front ball joints knuckle
Front anti roll bar end links
Front Upper A arms
Rear trailing arms bushes(couple sets of them)
Rear upper arms
Total cost to replace all genuine OEM undercarriadge parts should be around rm1800-rm2000.
For anything else, they are either doing partially or using asahi or knockoff parts.
shiroitenshi
3,676
170
Actually I'm not sure what knockoff part brand, but once, when I was asked to press in a bushing for an EG lower control arm, the bushing was actually smaller than the hole.. (O_o)
For me, that's another reason to stay off knockoff parts.
I'm using polys, but I don't find them stiff at all. Perhaps because I keep my spring rates in the softer ratings. The only drawback to using poly bushes for me is a little squeak at very slow speeds.
Kobra
89
1,508
You definitely have to replace for front and rear:
a. Upper control arm (Front & Rear)
b. lower control arm (Front & Rear)
These are the other main things that you need to change as well
1. Antirollbar link (front & rear)
2. Front compliance bushes
3. Front knuckle ball joints
4. Rear Lower arm main bushes
5. Stabilizer holder bushes
Go and buy these parts at any reputable honda stockists, then have them installed at your prefer workshop that you trust.
Or go to HSC.
Always insist those original Japan parts if you plan to keep the car for long, but stand by 2 grands for them.
If you just wanna drive it for another 2 years then those original but made in Thailand.
Hikaru,
Im planning to change all the bushing for my EK 2 door,
where can i get those Honda original bushing from? im from pantai timur la
u did mention bout HSC? what is that? it is Honda part supplyer?
any idea how many bushing for EK 2 door?
thanks..
caleb_5375
1,293
14
just to share my experience to all honda member...i just change my car bushing with energy bushing...those bushing given is more then superpro can give.with energy bushing u got the steering rack bush even ur tie rod end bush oso have...i can snap few pic when i free to share with u all...i oso change my rear arm to aluminuim one(not the lower arm ya..beside lower arm one) it cost me rm1600 for the product...after fix this product whole car really like new...
---------- Post added at 11:00 PM ---------- Previous post was at 10:10 PM ----------
to share how it looks on the rear side..
killa626
269
Hikaru,
thanks..
So this means that the pictures above are all the bushings that needs to be changed? There is no other?
Regards,
G.
Immitation Unbreakable Autolock!
I've notice the packing Autolock #1440 and Autolock Pro #1645 selling in Carrefour and Ace Hardware are related with T-rex, and when i visited t-rex website, the products info links to http://www.megacell.com.my/products/products.asp. Besides there are some forumers claimed that those selling in Carrefour and Ace hardware are half of the price of the Original Autolock selling in...
