Where to change bushing for my EG
rizzo8
44
Could anyone recommend a good workshop in KL / PJ/ Shah Alam area to change the suspension bushings for my hatch?
I'm planning to change the LCA, ARB bushes, and also rear suspension bushes as well.
How much am I expected to spend for this? Using standard rubber bushes.
Thanks in advance.
rizzo
EG8
2,107
www.surfer-girl.com
Thanks in advance.
rizzo
done it last year in subang jaya.the shop has their own machine for the bushings.1 day job.
u mean standard original OEM or local bushes? try to souce the parts at spare part shop and send it to the mechanic who have the machine and experience doing it. it cost me around rm1K plus including labor.
danieL
686
if u are around pj area u can try avantgarge mechanic near tmn bahagia, i did mine there. if change everything should be about 1k ++
acel
93
Hikaru & daniel
U guy change bushing for 1000++, is this just front or front & rear??
joni_loco
375
why use OEM bushes when you can get SuperPro bushes for a nearly same cost? PM me for details fellas...
rizzo8
44
Where can I get the parts in Shah Alam, Puchong area? Since its near my office, easier to sneak out during lunch and go buy them.
Definitely will avoid getting local/ Thailand parts.
Hikaru/ Eg8, could you tell me which shop did you guys go?
I think subang jaya is quite close enough. Thanks for your
help.
EG8
2,107
www.surfer-girl.com
help.
rizzo
let me check back and will update u accordingly then thanks
gunn
826
crower75 said:
Once u've changed them all....you'll be surprised how your car will "stick" to the road....a whole new set of suspension.....
then rembat uphill genting kaw-kaw.....isn't it?ekekekeke
stimGILER
223
it will stick until yur cannot cannot move loorr .. :biggrin: :biggrin:
artcap
84
bro daniel,
mind sharing the exact cost? is the cost just to change all bushes + labor or u changed all parts like bro Hikaru did?
out of topic, anybody know wats the price of just one knuckle set for eg? maybe chop shop price coz i need to change my front left knuckle. :frown:
thanks
rizzo8
44
ya lah, plus hopefully can get rid of the squeak noise and the "loose" feeling whenever driving uneven roads.
Just checked yesterday the lower arm bushes already got cracks and feels lembik. i've been spraying silicone to the bushes for such long time, it needs to be changed pronto.
EG8 pls inform once you have the nfo.
Thanks!!
The Marketplace Top Posts
Since out side is so much of model for weber i not really understand for those weber.. just wan sum sharing here for let me know more .. bcoz i veli intereted in weber topic.. wats the diff DCOE DCFN i forget the name just tell me wat the diff between that.. and sum is twin weber some is single.. wat the diff also? for a 1.3 carbie.. is perfect suitable is which weber? after using the weber wat is the topspeed? and 0-100km/h? i really interesting in weber.. thxxx
