The 4agze Forum
miriguy
887
20
will changing a new knock sensor solve my problem at 5.5k?
lilwhite
354
im using a 4afe ori knock sensor........no rpm cut at all~!!!! juz used it 2day~!!!!so happy~!!!
miriguy
887
20
good to know that. i have with me a knock sensor from Supra. When i look at the engine, it seems almost impossible to reach it. how did u change it? whats the easiest way to reach it? TQ
miriguy
887
20
i think what he is trying to say is about the power loss at 5.5k rpm.
i had that prob as well when i was trying with another SC. My boost is 1.05 bar and he is only merely 0.8 bar. surprisingly he can catch up with me.
lilwhite
354
to change it aa......mine ori knock sensor worn off....so i try my luck on my 4afe knock sensor...it works.....and yeah...there is no power dip at 5.5.......im sorry i really hav no idea how 2 change it....
and according to wat miriguy says....i think da 0.8 boost must hav done some tuning on da fuel supply.....
miriguy
887
20
can you ask your mechanic how he reach the sensor?
whats yr boost level now?
c70
168
Hi... I have ae101 gze into ae92 longmeter.
Had the same problem with you.
So I used the old speed meter gear from ae92 gze connected to the long speed meter. But problem is i still have my original ae101 speed meter gear connected and hanging in the engine bay, because if i remove it, i will get my engine check light on (because ecu detecting speed meter not running). *sigh*...HELP!!!
Then for rpm, I have used the digital to analogue rpm 'sensor' (don't know the actual term for it) from VR4. Its a square black color sensor with 3 connectors.
Mayb other sifus here can tell how they did their connection for ae101 gze digital meter to our local ae92/111 analogue meters?
Cheers.
guys....i juz installed da meter....from ae111....da speed and evthing is running good.....but oni da rpm is not working......anyone face these kinda prob b4???or its da prob wit da meter?
miriguy
887
20
today changed knock sensor to the one from a Supra. i still get the power dip.
what injector is best for 4agze?
miriguy
887
20
plug and play?
miriguy
887
20
i removed the ABV to test the power dip, still the same. what could be the problem? My charger or injector?
The Marketplace Top Posts
I own an old Proton Iswara manual 1.5. At times, I have problem starting the engine. It gives a tick sound but it doesn't work. I need to turn the key a few times to get it running. My car has already installed with a starter relay long time ago. In fact, I have just replaced a new relay. But the problem still persists.
I read somewhere that by giving a knock on the starter could probably fix the problem; that if the starter has no problem. Could someone tell me where exactly where is the...
