best intake manifold
mengz
605
4
3,018
if ur using the 4G93P, it does not have a distributor. therefore you adjust the ignition timing at the cam angle sensor.
deacon
Senior master debater
1,167
30
Uh actually no. 4G93P engines do have distributor cap.
Joeker
Walking Dead
3,580
62
Jinjang
GSR intake is slighter shorter and bigger in diameter by few mm.
I've used both intakes on my SOHC 4G92.
Not sure about MIVEC 4G92, but for SOHC version, you need to machine a pc of groumet to close off the EGR jacket at the head.
My 4G92 SOHC engine was Turbocharged, so I went for biggest manifold I could find (MIVEC overbore 65MM T/B + GSR intake)
For NA engines, need to maintain V/E. THerefore, going for the biggest and shortest intake is not that good an idea (unless matched with complimenting cams, extractors, gear ratios, A/F, etc)
deacon
1,167
30
how much did it cost you to overbore your inlet manifold? and how the heck did you manage 65mm on the TB? the guys in NZ can only manage 63mm.. must be a damn pro job.
WestCoast
194
yo what damn ur so kind to contribute for this thread love ya!
okok i'l be waiting for ur post lah
eh if can get mivec inlet manifold as well lar..hehe.. >.<
oh oh oso measure the diff and state it on the pic thx ya koko
WestCoast
194
bro deacon we can adjust ignition timing on the distributor cap? izit an easy job to be done? need an experinced enuf mech to do tat? will have any harm or cons to our machine for long term? like side affects? sowee ask so much noobie here
deacon
1,167
30
Umm it's the same as what i described on page 3
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
waa...joeker,4g92p turbo ar???how much hp u manage to achieve with ur
bot???mind sharing???what turbo r u using???
whatdamn
1,344
Cheras, KL, Mal
westcoast,
sorry for the delay, internet was down last night...but anyway, here it is.
from the pics, you can clearly see the different runner lengths and also the additional EGR runner and valve on the 4G93P intake manifold.
pls note that if you do purchase the 93T manifold, make sure you get the bracket that sits between the underside of the intake manifold and the engine block because your original one won't fit unless you machine spacers to fill in the gap in between, almost an inch between it.
WestCoast
194
bro what damn where is the EGR runner and valve located?
i duno c o sowee...
mengz
605
4
3,018
actually bro, its not really a distributor cap as well, because its not distributing sparks to the plugs.
its a sensor which is mounted onto the cam inside the body of a distributor that sends the crank angle position to the ecu which then tells the coils when to fire. so i believe its called a cam angle sensor.
but if im not mistaken, the 4G93 sohc runs on a distributor, correct me if im wrong.
WestCoast
194
ah..get it..yo bro whatdamn thanx so much lah u contribute a lot for this thread and wake up early in the morning jz to post the pic requested by me,hu u dun even know n also being patient and kind enuf to gv me the ans for my quest..thx a lot! malaysian rocks ^^
hi guys,
I am seriously annoyed by bees these 2 days.. i dunno why are the stupid bees doing their biz in my car exhaust!!! That’s very dangerous...
Here attached are some pictures which I took this morning and afternoon.
Lynn
