Wiring, Cables quality issues
et5828
just changed a new HU with amp and woofer
not the high end one, just entry level
that salesmen recommend me to change bigger wire and cable so that the sound will produce better quality
i'm noob in ICE and dunno whether wanna spend the buck for it
Pls advise, thx
Bigger wire as in Which wire? Speakers or power?
If speakers, most probably not needed.
i think the salesman advising the power cables la...
check again the fuse rating on your amplifier and roughly how long is the power cable, then only can advise u on what thickness of power wire should be used. if its too thin and too long, it will run very hot and sometimes can burn...
use normal 1 can oredi...if u goin high end, then baru consider better wiring..
okok
how bout the HU wiring?
he said the wiring is thin & recommended to change thicker
does this mod produce better sound clarity?
normally yes... but for your case minimal i guess... and different wires yields different sound characteristics... but not all can hear it...
so in which case... lets talk about what thicker wires were you offered? if its jus another chicken wire then save your money for CDs instead...
jus my 2 cents...
cheers....
where to get a branded speaker cables??
belstein for example..........anyone know?
belden u mean? pasar road osso got, i think most electrical contractor osso can get, theyre one of world's biggest cable makers, thousands of models...
Write your reply...
