unidentified brake problem...
littlewings
hi guys. i've a questions here regarding my rear brake. whenever after i wash my car or rainy days and i leave my car to dry it seems like some problem with my rear brake. it's like the caliper is stuck to the rotor for a while when i'm on the 1stgear (to make the car move on the first place). i had to push the gas harder to make my car move then it's gone.
what seems to be the problem here? i'm using ae101 with rear disk brake. thanks for any comments
i think it is called KARAT laa .. hehehehehe
its totally normal laaaa ... sometimes it happens one maaa ..
Should be karat. Last time went to service my car and the mechanic say just skim a little bit..It really does work.
haha...i'm facing exactly the same problem...but foremans said tat's normal circumtances for chopshop rotor....
Check to see if the metal shims (I think thats what they call it, it's somewhere between the brake pad and calipers) is there. Just a wild guess.
oh..karat@rust ah?? just gosok where the karat is la..ok
i will do that...thanks man...
if disc warped then skim laa ... if not u gosok oso not point one coz after wash car or rain it will karat again one maa ... the pads are metal oso ... so will be sticky to the disc one maa ....
only way to solve this is u dont tarik handbrake when wet lorr ... huahahahahaaa
yep karat loh de issue jes skim little bit n den run in loh later dun drive so fast.. slowly de pad will grip to it liao.. ehheheheeheheh!
Regards,
Mike
