AE111 hand-brake light comes on after hard acceleration
heng1028
I have been seeing the hand-brake light comes on when I acclerate hard, after I lift my foot off the pedal, the light goes off after a few second.
I wonder what is wrong with the light or the hand-brake??
the only modification i have is i change the rear drum to disc brake.
Installed for almost 4 months but this problem just recently surface.
anyone has similar problem like mine?
please shed some light here. thanks
check ur brake fluid level mate.
the car was trying to tell you not to press too hard
drive safe & steady
:_:
or your car is very powerful, that even the switch for the hand-brake was pressed under the G force:argh:
the brake oil level is on its min and not below
i guess when i accelerate the fluid is pushed all the way back and left the front portion under the min line.
will try to top it up but no time till friday.
will keep you posted.
thanks for the helps guys
hope our help could really work...
